| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
hi guys
i would like a power transformer of 300v secondary can i make this from 2 off the shelf power transformer? PT1: pri 220v sec 0v 20v 1A PT2: pri 220v sec 0v 15v 1A is it possible that i do it this way: connect the secondary of PT1 20v to secondary of PT2 15v and take my required 293v (if my calculation is correct and there is no iron loss) from the primary of 2nd PT? and how to calculate the VA rating from this kind of setup if above setup is possible TIA Erwin |
#3 |
Better still, buy a 1:1 isolating transformer.
Adapt any mains toroid transformer to make your own autotransformer to give any voltage you require. Power the autotransformer from the isolated secondary and you are safe and completely flexible. You can even use a Variac as your continuously variable autotransformer in complete safety.
regards Andrew T. |
#4 |
thanks wakibaki for the warning. its noted
how bout this: piggyback the 15v 0v 15v with the 20v 0v 20v? does the winding can withstand the 293v? does it become balance? as each end have half the voltage? sorry if this question is ridiculous. i am learning. TIA |
#5 |
hi,
the turns ratio of the transformers is not what you might expect. Let's take your first example using 15Vac and 20Vac transformers. Both are small, 15VA and 20VA and likely to have regulation in the range 10 to 20%. The open circuit voltage of these transformers will be ~15 * 1.15~=17.25Vac and ~20 * 1.12~=22.4Vac. These can be used to determine the turns ratios. 220:17.25 and 220:22.4 Now use those ratios to determine the open circuit output voltage. 220*22.4/17.25~=286Vac. The regulation of these cascaded transformers will be worse than the lower rated, i.e. worse than 15%. Let's assume 20%. The rated output voltage is ~ 286 / 1.2 ~=238Vac not 293Vac. Go back to post3 and build your own isolated autotransformer. You can check the turns ratio by measuring the actual input and output voltages when the secondary has no load.
regards Andrew T. |
#6 |
running the 2nd transfromer at higher V, same frequency also increases B in the core - power transformers are usually at the edge of acceptable loss with nominal line V for economic reasons
line power xmfr cores are operated at a very nonlinear part of their curve and Imag increases nonlinearly with V*t the increased B in the core will draw lots more magnetizing I and increase losses more quickly than you might expect |
#7 |
hi guys
thanks for all the help and pointers. will look into them jcx, yep i tried piggyback 2 PTs to give out the same voltage as the main, trying to create isolation transformer from 2 off the shelf PTs, the output voltage is lower than mains. at one times i try to draw only 1/2 of the rated current. the input volt is 220v but the output is only 190v. but they bring benefit to the circuit as long as lower voltage wont create problem. Erwin |
| Tried to piggyback two AK4395 dac chips | sendler | Digital Source | 1 | 4th February 2009 06:59 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Little Piggyback Capacitors | CarlosT | Chip Amps | 9 | 4th December 2006 03:16 PM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
| AD1865 in piggyback | cmt42001 | Digital Source | 6 | 10th November 2005 09:30 PM |
| Page generated in 0.10668 seconds (79.33% PHP - 20.67% MySQL) with 10 queries |
