Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Blackgate N series polarity
Old 5th March 2009, 06:45 AM   #1
calvinhpk is offline calvinhpk  Malaysia
Default Blackgate N series polarity
The Blackgate N Series are known as no-polar cap,
does that means that I can mount it either way, don't care about the polarity of positive or negative?
Old 5th March 2009, 07:01 AM   #2
bambadoo is online now bambadoo  Norway
Yes you are right
Old 5th March 2009, 08:08 AM   #3
Originally posted by bambadoo
Yes you are right
does it sounds different mounting it different direction?
Old 5th March 2009, 08:20 AM   #4
I really don't know. Have not tested.
However it is said that some caps sounds better one way than the other.
Look down at this link
http://www.audionote.co.uk/comp/cap_paper.shtml
Old 5th March 2009, 09:01 AM   #5
poynton is online now poynton  United Kingdom
poynton's Avatar
Don't BG recommend mounting in pairs - one facing one way, the other the reverse direction ???
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 5th March 2009, 01:16 PM   #6
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Blackgate N series polarity Send a message via AIM to Peter Daniel
They can recommend whatever they won't but mounting them in pairs never sounded good to me. As to BG N orientation, I like them with short pin (NONPOLAR print side) on +
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th March 2009, 08:30 AM   #7
Andy
did they??
where did you read those?
Old 9th March 2009, 03:47 PM   #8
hafp is offline hafp  United States
Do a search for BD N, NS, NS Hi-Q in Super E configuration.
There was much written about this recommended configuration; with much debate pro and con...
Cheers.
Old 9th March 2009, 03:51 PM   #9
poynton's Avatar
Originally posted by calvinhpk
did they??
http://www.acoustic-dimension.com/bl...e/techEcap.htm
Andy
Blackgate N series polarityHide this!Advertise here!
Blackgate F Series sma Parts 1 19th April 2007 08:17 AM
Blackgate n series coupling direction dsavitsk Digital Source 14 27th December 2005 08:57 PM
Upgrade Sonic Impact with Blackgate PK series caps justpoor Class D 12 21st May 2005 03:56 AM
Blackgate F Series Electrolytic sma Parts 1 24th January 2004 09:57 AM
Blackgate F Series Electrolytic sma Swap Meet 0 24th January 2004 07:22 AM
Copyright ©1999-2017 diyAudio
