Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
AM Radio Antenna
AM Radio Antenna
Old 11th March 2009, 02:47 AM   #21
infinia is offline infinia  United States
infinia's Avatar
1) Try common mode choke described above
2) You could also try your RFC in the power supply ground lead.
3) Also try a battery instead of the PS.
4) Don't leave any scope probe grounds attached.
All are fixes are for the same thing...
The bottom of your ant loop is attached to the ground (ultimately gnd of the building AC wiring?) of your SE radio unbalancing it.
Old 11th March 2009, 12:07 PM   #22
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
AM Radio Antenna
Dunno if you tried it already, but have you tried reorienting your antenna? Loop antennas are very directional, you might be pointing right into a null. Also, orientation should usually be with the axis parallel (not perpendicular) to the earth. Move it around before you give up on it.
Old 11th March 2009, 07:00 PM   #23
Mark245 is offline Mark245  United States
Ok thanks! I will try all of this and let you know how it goes.
mark
Old 27th March 2009, 03:25 PM   #24
Thanks Infinia! The common mode choke seems to be the answer to the problem. Do you know why this fixes the problem? I read part of the link from your previous post but it still is not quite clear to me. At least I have a radio that works now without having to touch the antenna. I guess my hand was acting as a common mode choke? Thanks!
Old 28th March 2009, 12:42 AM   #25
infinia's Avatar
Hi Mark
Glad you got your loop working.
Re> common mode choke. It's really called a balun in this application. The real simple explanation is that itís useful as buffer between a balanced antenna and an unbalanced circuit.
BALUN = BALance + UNbalanced
Itís also used to keep the transmission line from unduly interacting with the antenna and possibly re-radiating the EM energy collected. Google antenna and balun for more indepth discussion.
edit>
Another way to look at it
The balun choke looks like a large inductance for currents traveling down both conductors (common mode). And looks like a low inductance for differential currents ie balanced currents returning to and from the source (they cancel each others magnetic field in the core).
AM Radio AntennaHide this!Advertise here!
car antenna coki Car Audio 3 11th August 2007 11:35 AM
car radio antenna petercampusa Car Audio 1 29th April 2006 08:21 AM
Antenna ? fortuosity Everything Else 1 17th October 2005 10:14 AM
Wiring for Home XM Radio Antenna joeytt64 Everything Else 0 23rd February 2005 06:40 AM
What do you think about this antenna ? darkm4n Parts 0 6th March 2004 09:47 PM
