Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th February 2009, 09:47 AM   #1
revans is offline revans  New Zealand
Default Filter for 4" FR Tang Bands
Hey there,
I'm making my first set of speakers (it's actually a portable boombox) and have a quick question before I wire them up.
There are two enclosures driven by an Amp6-Basic with one 4" Tang Band W4-1320SB full range driver in each enclosure. The dimensions of each enclosure are 125x145x230mm with a round port of 38x90mm. The drivers parameters are:
Qts: 3.7
Vas: 5.9 litres
Fs: 75 Hz
Re: 6.8 ohms
Qms: 1.5
Qes: 0.48
SPL: 89.02 dB
Pe: 25 watts
Now I've given all the technical stuff... onto my question:
Throughout the various threads I've made during this project, I have been told several times it would be wise to add a filter or some such thing to eliminate lower end bass as it could damage the speakers. Personally, I have no idea if this is necessary or not or how to implement it. So, basically I was wondering if anyone could please enlighten me on what exactly this filter I may/may not require is, whether it would be good to put in and how to go about that.
Thanks for your help.
Old 28th February 2009, 01:56 PM   #2
mjf is offline mjf  Austria
hello.
there is a slip of pen: qts=0,37
usually you do not need a subsonic filter i think.
only for special applications,like in combination with a subwoofer or so.................
simpliest filter is a non polarised electrolytic cap round about 1000uf in series with the box.
greetings..................
4 inch Tang Bands..... type Full Range 17 19th September 2006 11:56 AM
More Zaph's Tang Bands cj.9 Multi-Way 0 1st January 2006 09:56 PM
EBS Aligned Tang Bands? sharpi31 Full Range 4 28th November 2005 12:16 AM
Zaph's Tang Bands ? cj.9 Multi-Way 5 22nd June 2005 12:52 AM
Resistance box for Tang Bands Eccu Multi-Way 1 25th November 2004 08:33 PM
Page generated in 0.06643 seconds (70.96% PHP - 29.04% MySQL) with 10 queries
