| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello to all.Working on a sansui 1000a tube reciever. On the main power transformer there are 2 diodes #Si, diode AC (rms)180v@500ma. on 1 circut & 1 diode # selenium diode ac 45v@25ma on another circut. Can I swap these with 1n4007 type diodes? (these diodes are not the rectifier diodes.the rectifier has 6 glass type Ge diode 90v@50ma.What can I change these over to? Thanks, tom
#2 |
Here are two sites where you can find diode details: http://www.alldatasheet.com/view.jsp?Searchword=4049 and http://www.datasheetarchive.com/ Al the best. Regards. ct12 |
#3 |
Replacing a selinium rectifier with a silicone diode is usualy a little
more complicated. The silicone diode will give you a higher output voltage you may need to make an adjustment for this higher voltage. |
| SMD diode ID please | Perry Babin | Parts | 5 | 8th October 2008 03:14 AM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| What is this diode for? | lumanauw | Solid State | 15 | 6th January 2007 05:14 PM |
| Is it a Diode? | imix500 | Parts | 14 | 28th June 2004 12:17 PM |
| Page generated in 0.07328 seconds (70.05% PHP - 29.95% MySQL) with 10 queries |
