capacitors - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th February 2009, 10:23 PM   #1
dognut is offline dognut  United States
Default capacitors
Hello to all.recapping my tube reciever. The caps that come off the 7591 tubes are elna 0.3uf @ 400wv. can I put two 0.15ufs together to get the 0.3
Old 25th February 2009, 10:41 PM   #2
Put both 0,15uF in parallel, and yes, you obtain a total of 0,3uF. Of course each of the 0,15uF capacitors should be rated for the same voltage as the 0,3uF unit!
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 26th February 2009, 06:35 PM   #3
whitelabrat's Avatar
You may be able to get away with a single 0.33 instead. Or even a 0.47 or 0.22.
Old 26th February 2009, 07:50 PM   #4
m6tt is offline m6tt  United States
You can reduce the grid leak for the 7591 (assuming the driver can handle it) and use a larger cap and have the same frequency response while putting less strain on the 7591. If they're say 220k, you could make them 120k and use a .47uF. This all really depends on how stressed the driver is already, so if it's a 12ax7 this is probably out.
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Oil capacitors Praudio Swap Meet 3 7th October 2003 03:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Copyright ©1999-2017 diyAudio
