Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th February 2009, 11:35 PM   #1
Default MBR4060PT dual schottky rectifier as bridge rect.
I got a dozen or so of these for free and wanted to check that they would be a good choice to use two of them and form a bridge rectifier as part of a DC power supply.
http://www.fairchildsemi.com/ds/MB/MBR4060PT.pdf
60V max reverse & 40A average rectified forward current. Should be enough ;-)
Old 25th February 2009, 12:58 AM   #2
Can't answer that till you show us the circuite you intend to use them in transformer type, voltage ect.
Old 25th February 2009, 01:53 AM   #3
Of course, sorry about that. Its a capacitance multiplier supply that my son wants to use for a JLH 2005 Class-A amp.
http://www.tcaas.btinternet.co.uk/jlhcapmult.htm
Transformer is dual secondary 32-0-32 400VA
C1 & C2 in that schematic will be dual 10,000 uF 75VDC - 20,000 uF per rail.
Old 25th February 2009, 02:45 AM   #4
Don't think so. The problem is the 60v reverse breakdown rating.
Take a look at just the + cap. The 32 v ac will charge the cap
to about +42v during the half cycle it's charging but on the other
half cycle the diode will see 42v+ from the cap and - 42v from
the transformer for about 84v across it this excedes the 60v rating.
Old 25th February 2009, 05:21 AM   #5
Thanks Woody,
I'll pick up some MBR20200CT's I think
bridge rect. upgrade question on PE BASH 500 crippledchicken Parts 2 4th September 2007 02:09 AM
Schottky rectifier cricuits dqswim Pass Labs 4 9th January 2004 10:00 PM
Schottky bridge rectifier TheTrax Tubes / Valves 5 3rd January 2004 11:28 PM
International Rectifier Schottky diodes KevinLee Swap Meet 17 30th June 2003 10:37 PM
FYI: SiC Schottky bridge rectifiers JohnG Solid State 1 27th July 2002 06:40 AM
Page generated in 0.09401 seconds (68.97% PHP - 31.03% MySQL) with 10 queries
