Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd February 2009, 04:50 PM   #1
suicida is offline suicida  Greece
Default Logarithmic Pot. instead of linear?
Hello,
I am new here and this forum is incredible.
I have a very old pioneer amplifier and i want to change the volume and balance pots.
My problem is that the volume pot is a dual linear with loudness control at 100KB and cannot find to buy a new one.
My question is:
Can I use dual logarithmic 100KA with loudness control pot instead of the dual linear 100KB pot?
For the balance what pot should i use linear or logarithmic?
Thanks a lot for your help.
Old 23rd February 2009, 04:58 PM   #2
h_a is offline h_a  Europe
h_a's Avatar
I'm not sure I understand you correctly?
You cannot replace a linear pot with a logarithmic one without changing the surrounding electronics in your amp - double logarithmic ain't no fun
Balance is usually a linear pot.
Have fun, Hannes
Old 23rd February 2009, 05:11 PM   #3
some balance pots have zero resistance in the track over half the sweep range.
regards Andrew T.
Old 23rd February 2009, 07:11 PM   #4
My amplifier is a Pioneer SA-720 and the volume potentiometer writes 100KB(1). I was wondering if you can tell which one i should use (linear or logarithmic)?
Old 23rd February 2009, 11:04 PM   #5
Tube_Dude's Avatar
Logarithmic!
Jorge
A twisted tale about a logarithmic relay attenuator Russ White Parts 663 1st July 2011 09:23 PM
really weird linear potentiometers that have a logarithmic response VvvvvV Instruments and Amps 8 30th March 2007 10:00 PM
Logarithmic potentiometers eeka chu Parts 3 31st December 2004 01:17 PM
100K Noble logarithmic pot 2Bak Chip Amps 7 27th January 2004 10:46 PM
Logarithmic attenuation FunkyStu Solid State 4 31st December 2003 02:54 PM
Page generated in 0.08116 seconds (73.71% PHP - 26.29% MySQL) with 10 queries
