Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th April 2003, 03:47 PM   #1
Default Looking for transistors
I am looking for some of those big plastic case transistors that are completely encased in plastic so as not to have to use insulator gaskets. I need them for the output stage of a power amp. (bipolar) Does anyone know the numbers of any of this type of transistor? What is the case type? Thanks so much for your help.
Where there is smoke....there is fire. (usually one of my circuits)
Old 17th April 2003, 04:15 PM   #2
MikeW is offline MikeW  United States
MikeW's Avatar
The parts you are looking for are to-264 packages. They still need an insulator between the transistor and the heatsink. On Semi has the MLJ21193,21194 and the MJL3281,1302. Look at Digikey, Future, and Mouser for prices.
MikeW
Old 17th April 2003, 04:21 PM   #3
rMa is offline rMa  Finland
Hi willy,
I'm not sure what you mean by big but one type used by ST is TO-220FP. BD241BFP and BD242BFP are one example of their isolated type complementary pair.
I think ISOWATT220 is also commonly used name for this package.
- rMa -
Old 17th April 2003, 06:06 PM   #4
Apex Jr is offline Apex Jr  United States
Default MJ 10051
Willy....
I have a large stock of Motorola MJ 10051
BiPolar Transistors. They are 850Volts 50Amps
They roughly are about 2" Square and are NPN
The case is a 346-01
Price...... $3.95ea
Steve @ Apex Jr
Old 20th April 2003, 06:33 PM   #5
blmn is offline blmn  Brazil
blmn's Avatar
willy
Actually you will find some devices in ISOWATT style (fully isolated devices).
I made, sometime ago, an amp using the NPN/PNP pair TIP33/34CF, where the F means fully isolated, made by CDIL. They might have other fully isolated power devices available.
But you have to be aware of the power dissipation questions when using this type of packages in high power applications.
Except if you have some special application or problem wich make the insulators use not possible, I think you must consider the traditional non-isolated device plus insulator mounting.
regards,
old RCA transistors- what are they? needtubes Parts 10 14th June 2011 04:49 AM
what transistors to use? prorms Solid State 1 20th November 2006 06:14 PM
Best transistors YUTK Solid State 1 20th May 2005 05:16 PM
transistors Dj BASS AMP Solid State 1 31st March 2003 05:46 PM
transistors lemondog Swap Meet 5 1st March 2002 08:05 PM
Page generated in 0.07832 seconds (71.66% PHP - 28.34% MySQL) with 10 queries
