Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need a little help with wiring a relay
Old 21st February 2009, 01:16 PM   #1
sensibull is offline sensibull  United States
Default Need a little help with wiring a relay
Hello,
This might sound a little whacky, but I'm building a music server inside of an old Philco radio case. This is the third I've made actually, but I'm trying to get a bit more sophisticated with my wiring.
Inside the shell will be a mini-itx based computer and an amp. I only want one power cord and one power switch and I want the amp to power on with the computer.
Can I do this by wiring in 120vac relay with a 12v coil and using the (unneeded) 4pin molex on my PSU as the trigger? I have a rotary momentary switch to power on the computer. Would I would just need to wire the mains power into a block and route the hot, ground, and common wires properly from there?
Old 23rd February 2009, 11:41 AM   #2
Anybody?
Old 23rd February 2009, 01:03 PM   #3
Dan2 is offline Dan2  South Africa
it will work, but chances are that the amp will turn off after the computer does which might make a noise.
just remember to put a diode in parallel with the coil, reversed, this will protect your PSU against the reverse voltage spike that the coil produced at switch-off.
Old 24th February 2009, 08:01 PM   #4
Thanks for the tip re: the diode.
Um... What kind of diode
edit: seems I need a signal diode, but what specs and where to find them?
Old 25th February 2009, 04:50 PM   #5
any diode will do
Need a little help with wiring a relayHide this!Advertise here!
Wiring up a 240V relay? westers151 Everything Else 32 22nd March 2009 10:14 AM
Relay input selector wiring help needed! zoranaudio Solid State 1 31st July 2008 06:58 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Copyright ©1999-2017 diyAudio
