Outer foil k40y-9
This is my understanding. I'm hoping someone will correct me if I am wrong.
Is this really necessary? I have just built a linestage and the final output caps are audionote foil, I was on the website earlier and it appears that i have installed them the wrong way round! beginners luck!! my question is... will i really notice if i turn them around?
cheers stuart
sorry if I manage an old 3d ;)
if it would not make much sense I would like to understand if in theory it is better to put the inner foil (therefore more shielded) in input to the signal or in output.
I think it is better to put the inner foil in the imput of the signal, to better shield.
what do you think about ?
Need to measure to be sure with those if I recall correct.
Fit with outer foil end to lower impedance side. So outer foil end to ground if it is a decoupling application, or signal in the outer foil side if in a signal path application as the previous stage will be the lower impedance side.
diypass, fitted these ways provides better noise rejection.
Where To Connect the Outside Foil on Capacitors
