Geek said:All the el-cheapo's I get from Digikey show an inductance
Cheers!
Most likely not in the higher values used in tube circuits.
Most likely won't find any past a few hundred ohms or so. You could DIY using really thin nichrome wire and a ceramic form. Better to just add an inductor in series with a resistor IMO.
edit>something like this with 1000V rating (tube plates)
http://thunder.manufacturer.globals...nd-resistor/1009319206/Wirewound-Resistor.htm
in general http://www.globalsources.com/manufacturers/Wirewound-Resistors.html
