Where to Purchase Crossover Parts - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th February 2009, 04:30 AM   #11
lowtherdream's Avatar
Nice size listening room
I prefer to keep things simple and put my money on the drivers. With fullerange drivers, no need to worry about crossovers and the complexity of matching drivers and making everything sound right.
If you want added SPL, you will need larger drivers, 6" or 8". Fostex makes nice drivers at a reasonable price.
Nice driver at 96 dB/m
http://www.solen.ca/pdf/fostex/fe206e.pdf
If you have electronics near the drivers, you will need the shielded magnet 95dB/m
http://www.solen.ca/pdf/fostex/fe207e.pdf
and the 97dB/m
http://www.solen.ca/pdf/fostex/fe208ez.pdf
Hemp acoustics FR8c @ 95.5 dB/m
http://www.solen.ca/pdf/hemp/FR8C.pdf
The modified Fostex 206 from Decware
http://www.decware.com/newsite/DFR8.htm
and the High Definition Towers ... a great project if you buy the kit
http://www.decware.com/newsite/HDT.htm
http://www.decware.com/newsite/htdkits.htm
Of course, there are many other options like Audio Nirvana drivers
http://www.commonsenseaudio.com/
and the Lowthers
http://www.lowtherloudspeakers.com/homeindex.html
Making a cabinet with Lowther drivers is my dream ... but I need to get better at it before I spend that amount of money for drivers. My 1st project was a custom design BLH with Fostex FE207E drivers. It was a great learning experience and the result is great for a 1st cab. My next step is the Decware HDT, in preparation for the Lowther project I am still unsure if I will go with a known cabinet design, or create my own.
surfing the 2nd harmonic ... @@@@
Old 9th February 2009, 02:52 PM   #12
Wow, the lowther looks nice, very nice!
What do you think about Mark-Audio drivers?
Old 9th February 2009, 10:37 PM   #13
It is the 1st time I hear about them. They are rated 85dB/m which indicate that you will waste power to drive them, when compared to the more efficient 95 dB/m + drivers. If you believe in the importance of the 1st Watt of sound, you will stay away from less efficient drivers.
Check the Loudspeakers/fullrange posts for tested recipes.
Oher great sources of info:
http://fullrangedriver.com/singledriver/
http://fullrangedriver.com/forum/
Old 9th February 2009, 10:41 PM   #14
Madisound is also a good source for drivers:
http://www.madisound.com/catalog/index.php?cPath=45
and a good list of driver manufacturers:
http://audiotools.com/drivers.html
Take also a look at AER and Manger drivers
Old 9th February 2009, 11:12 PM   #15
Reality first!
ClaveFremen's Avatar
Originally posted by samsagaz
Is OK to purchase Mundorf M-CAP® Supreme as my Polypropylene Caps?
For tweeters absolutely YES!
For midrange, if cost is no object, yes
For woofers go for a nice Polyester or a normal Polypropilene
Consider also Audyn Cap Plus (similar quality, lower price)
I really think that if ppl purchase 150-200USD caps to make an crossover, they maybe can spend more money purchasing an better driver!, how is possible that caps will be TOO EXPENSIVE?!?!!?
im thinking seriously abt go to 3 ways or just spend all these money in maybe better drivers.
'Boutique' caps are expensive but with Mundorf Supremes (they're not the most costly!!) I've had great results with my Alphas.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 9th February 2009, 11:24 PM   #16
Thanks too much for your support, i will try to purchase some efficient driver.
will read the info that you post and of course will ask some other questions later
Old 10th February 2009, 02:13 AM   #17
WOW
Exist a lot of manufacturers!
Old 12th February 2009, 12:35 PM   #18
And may I humbly suggest, as a good source for crossover capacitors: www.audiocap.co.uk
Crossover Parts Timn8ter Swap Meet 4 1st December 2008 06:52 PM
Help with crossover parts..... audiokid25 Multi-Way 0 25th July 2005 09:38 PM
Parts for this crossover The Paulinator Multi-Way 4 13th April 2005 04:10 PM
Best place to purchase Crossover ... squidbait Multi-Way 8 31st March 2004 01:01 PM
Crossover parts??? Per Nielsen Multi-Way 4 16th March 2003 03:05 PM
Copyright ©1999-2017 diyAudio
