http://www.madisound.com/ (Hovland caps)
http://www.northcreekmusic.com/ (for nice inductors especially)
http://www.partsconnexion.com/partscomponents.php (Mills resistors, various caps)
ok, this is my first time building/purchasing some components to build an Crossover, i have a few questions.
Is OK to purchase Mundorf M-CAP® Supreme as my Polypropylene Caps? or is just better to spend more money and try to purchase any oil capacitor?
and About Polyester caps, wich brand you recommend?
There are a lot of different opinions about the subject. Unless you have the opportunity to compare yourself, you will have to rely on somebody's opinion. I cannot personally comment on the subject having BLH loudspeakers with a single fullrange driver.
You can start with these:
http://www.audiocircle.com/circles/index.php?topic=54218.0
http://www.humblehomemadehifi.com/Cap.html
http://www.tempoelectric.com/caps.htm
http://www.vhaudio.com/21capacitorshootout.pdf
http://www.10audio.com/sonicap_oimp_multicap.htm
Another good source of capacitors is
http://www.parts-express.com/crossover-capacitor-index.cfm
wow, after read some reviews, i really was thinking.... is good to go 2 or 3 ways ? :S
I really think that if ppl purchase 150-200USD caps to make an crossover, they maybe can spend more money purchasing an better driver!, how is possible that caps will be TOO EXPENSIVE?!?!!?
im thinking seriously abt go to 3 ways or just spend all these money in maybe better drivers.
room size 6mt x 5mt.
Right now i have solid State Amps and some chipamps (i will build an tube amp this year, but dont know when).
i want more SPL, right now im using FR125S Full Range Drivers (using just one / box).
I sold an B&W 602 S2 a few months ago. I want to build an better box than my old B&W 602. I was thinking abt go 3 ways (was thinking abt build an Acapella SE because i have G2Si tweeters in Stock).
Was searching for other Full range drivers too, to avoid purchase expensive crossover parts, but dont know where to go!, i like the sound of FR125 but want more SPL for this room. Maybe build another box or use multiple drivers / box, i currently have 5 FR125 in stock.
Nice size listening room
I prefer to keep things simple and put my money on the drivers. With fullerange drivers, no need to worry about crossovers and the complexity of matching drivers and making everything sound right.
If you want added SPL, you will need larger drivers, 6" or 8". Fostex makes nice drivers at a reasonable price.
Nice driver at 96 dB/m
http://www.solen.ca/pdf/fostex/fe206e.pdf
If you have electronics near the drivers, you will need the shielded magnet 95dB/m
http://www.solen.ca/pdf/fostex/fe207e.pdf
and the 97dB/m
http://www.solen.ca/pdf/fostex/fe208ez.pdf
Hemp acoustics FR8c @ 95.5 dB/m
http://www.solen.ca/pdf/hemp/FR8C.pdf
The modified Fostex 206 from Decware
http://www.decware.com/newsite/DFR8.htm
and the High Definition Towers ... a great project if you buy the kit
http://www.decware.com/newsite/HDT.htm
http://www.decware.com/newsite/htdkits.htm
Of course, there are many other options like Audio Nirvana drivers
http://www.commonsenseaudio.com/
and the Lowthers
http://www.lowtherloudspeakers.com/homeindex.html
Making a cabinet with Lowther drivers is my dream ... but I need to get better at it before I spend that amount of money for drivers. My 1st project was a custom design BLH with Fostex FE207E drivers. It was a great learning experience and the result is great for a 1st cab. My next step is the Decware HDT, in preparation for the Lowther project I am still unsure if I will go with a known cabinet design, or create my own.
and the 97dB/m
and the Lowthers
It is the 1st time I hear about them. They are rated 85dB/m which indicate that you will waste power to drive them, when compared to the more efficient 95 dB/m + drivers. If you believe in the importance of the 1st Watt of sound, you will stay away from less efficient drivers.
Check the Loudspeakers/fullrange posts for tested recipes.
Oher great sources of info:
http://fullrangedriver.com/singledriver/
http://fullrangedriver.com/forum/
Madisound is also a good source for drivers:
http://www.madisound.com/catalog/index.php?cPath=45
and a good list of driver manufacturers:
http://audiotools.com/drivers.html
Take also a look at AER and Manger drivers
samsagaz said:Is OK to purchase Mundorf M-CAP® Supreme as my Polypropylene Caps?
For tweeters absolutely YES!
For midrange, if cost is no object, yes
For woofers go for a nice Polyester or a normal Polypropilene
Consider also Audyn Cap Plus (similar quality, lower price)
samsagaz said:I really think that if ppl purchase 150-200USD caps to make an crossover, they maybe can spend more money purchasing an better driver!, how is possible that caps will be TOO EXPENSIVE?!?!!?
'Boutique' caps are expensive but with Mundorf Supremes (they're not the most costly!!) I've had great results with my Alphas.
lowtherdream said:Madisound is also a good source for drivers:
Thanks too much for your support, i will try to purchase some efficient driver.
will read the info that you post and of course will ask some other questions later
And may I humbly suggest, as a good source for crossover capacitors: www.audiocap.co.uk
- Design & Build
- Parts
- Where to Purchase Crossover Parts
