Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd February 2009, 07:19 PM   #1
Default Panasonic EVJ
Bought two EVJ-YK1F03368 units
At max resistance:
unit 1, channel 1: 49.8 kohm
unit 1, channel 2: 48.6 kohm
unit 2, channel 1: 48.7 kohm
unit 2, channel 2: 47.5 kohm
at min resistance:
unit 1, channel 1: 5.6 ohm
unit 1, channel 2: 3.2 ohm
unit 2, channel 1: 5.5 ohm
unit 2, channel 2: 3.3 ohm
at center detent:
unit 1, channel 1: 41.6 kohm
unit 1, channel 2: 8.36 kohm
unit 2, channel 1: 40.6 kohm
unit 2, channel 2: 8.15 kohm
Is this normal? The two units show good consistency but what the heck is up with the resistance at the detent? I didn't measure resistance anywhere besides those 3 points.
Old 6th February 2009, 01:24 AM   #2
Also, at minimum resistance, the channels show significantly different resistance. I'm starting to think I really did order the wrong part - perhaps a tone control...?
(this post also serves as a bump )
Old 6th February 2009, 01:48 AM   #3
PH104 is offline PH104  United States
PH104's Avatar
I think you're measuring it wrong. The low and high ends are ok, but at the middle the sum of two readings adds up to the correct resistance so it seems that channel 1 is being measuring from "top to bottom" and channel 2 is measured from "bottom to top".
The spec sheet is at:
http://www.panasonic.com/industrial/...aok0000ce9.pdf
Old 6th February 2009, 02:15 AM   #4
I sure hope I'm measuring it wrong, but I can't seem to find the right combination that gets me the resistances I'm supposed to get.
I did check it. Staying with the same leads does not give me the right resistances in the middle.
Old 6th February 2009, 02:28 AM   #5
charted: merely check the row against the column for the lead resistances as per the datasheet
ah, the resistance between II1 and II2 for full CW should be 48.5k, not 48.5
Old 6th February 2009, 10:17 AM   #6
h_a is offline h_a  Europe
h_a's Avatar
That's perfectly normal for pots, lookup the datasheet, this pot allows +-3dB difference between channels - that's +-40%. Better ones guarantee 1.5dB, but only at higher levels - still 19%.
If it's logarithmic, it's not a tone control.
Have fun, Hannes
Old 11th February 2009, 11:14 PM   #7
I think I got the wrong part here.
http://dkc3.digikey.com/PDF/C091/P1948.pdf
The curve is AC whereas the correct curve should be A or D.
Damn it!
Old 1st March 2009, 02:06 AM   #8
I think I've figured out what I need for volume control; either the EVJ-Y10F03A24 or the EVJ-Y10F03A54 should work (vertical, metal bushing, A-type log taper, 20K or 50K respectively). If somebody could confirm that, I'd be quite appreciative.
However, my question now is whether 20K or 50K would be better for general use. Tracking seems to be better away from the extremes, so the 20K would stay away from the high end of the resistance. However, it seems that 50K is more common as a volume control. Some help here would be great.
Another new sub from Panasonic.. ashok Subwoofers 4 3rd August 2007 10:48 PM
WTB Panasonic WM-61A neilyboy84 Swap Meet 3 31st January 2007 04:41 PM
Panasonic WM-62 or WM-66 instead of WM-61? NickZ Multi-Way 2 20th December 2005 02:02 PM
Panasonic Pot AKSA Parts 2 10th March 2005 10:44 PM
Panasonic FCs jonclancy Parts 8 17th August 2004 08:30 PM
Page generated in 0.08313 seconds (85.55% PHP - 14.45% MySQL) with 11 queries
