| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm building a B1 buffer with the modification of using an LDR-based attenuator in lieu of a traditional potentiometer. To get the input impedance back up to around 30k, I'd like to insert some quality resistors like Vishay or Caddock and I wanted to get some sort of consensus on what type of resistor is best in that application and which manufacturer might sound best. In this situation are thin film, thick film, wire wound, etc best? What sort of wattage rating do I need? Should these be sinked to deal with the inevitable heat?
thanks in advance, Marc |
#2 |
In my experience, the lowest noise and most neutral resistors are the Vishay/Dale RN55D or RN60D. They are not ROHS compliant, but this is not an issue for DIY'ers. They offer performance way beyond their cost. 1/8 to 1/4 watt is all that's required for RNxxD's in a buffer/preamp attenuator. These resistors have a very underrated power rating. If in doubt, on power rating then go with the 1/4 watt.
Check www.mouser.com for prices. -David |
#3 |
Awesome. Thanks for the tip!
#4 |
Hello Marc Brown
Peter Daniel has covered this topic extensively on this thread: diyAudio Forums diyAudio Forums > Top >Amplifiers >Chip Amps >In search of a perfect attenuator In search of a perfect attenuator Yours Sincerely John |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| newbie questions for DIY audio - line-in attenuation | avid | Everything Else | 1 | 20th August 2006 11:08 AM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| TL sub - line exit options | Nuuk | Subwoofers | 15 | 20th August 2004 08:33 PM |
| Line Level attenuation | habana | Analogue Source | 13 | 14th May 2003 07:45 PM |
| Page generated in 0.07740 seconds (73.79% PHP - 26.21% MySQL) with 10 queries |
