Reforming Caps with Variac - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2009, 02:24 PM   #1
MZ is offline MZ  United States
Default Reforming Caps with Variac
Hello All:
I have two preamps which are powered off their respective amplifiers. Can both units (amp/preamp) be connected to each other and to the variac at the same time? Or is it better to do the amp separately and then connect the preamp? Appreciate your help.
Best, Mark
Old 29th January 2009, 05:57 PM   #2
Interesting question. To my way of thinking it is the power supply electrolytics that you are reforming with the Variac. These are in the power amp as you noted. It seems to me that only the power amp need be reformed. So to answer you question, I don't suppose it really matters. I'm no authority, so lets see what points the others raise.
-cd
Old 29th January 2009, 06:56 PM   #3
Should I bypass the rectifier tube with solid state diodes?
There ain't gonna be much emissions while the filament is
under voltage. And I don't want to begin the forming with
the Variac set high enough to effectively light the rectifier.
Old 29th January 2009, 07:39 PM   #4
HollowState's Avatar
under voltage.
Definitely yes. That is the proper way to do it. That's right-on thinking. I like to hook a voltmeter across the first cap and take the voltage up in 50V steps. The time interval depends on how long things have been dormant as well as general age. A milliamp meter in series with the rectifiers and first cap isn't a bad idea either. Any heating of the capacitors is crucial to watch for.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2016: 18 year olds need a safe place because words hurt their feelings.
tube rectifiers and electrolytic reforming w/ variac pjanda1 Tubes / Valves 11 19th May 2008 06:06 AM
Reforming capacitors? AndrewT Parts 2 23rd March 2008 06:21 PM
N.o.s Capacitors Reforming exurbia Parts 0 5th November 2003 04:38 PM
Caps, Hexfets, Variac CCOZGO40 Swap Meet 0 30th November 2002 12:14 AM
Reforming hi voltage caps kiwi_abroad Parts 1 25th November 2001 09:59 PM
Copyright 1999-2017 diyAudio
