Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th January 2009, 08:06 PM   #1
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Default Relay Question
Folks:
I'd like to build a simple relay-based source selector. Each relay will be connected to an input and a front panel-mounted switch, which will toggle between the various relays (and corresponding inputs). Can anyone tell me if the Omron G5V series (specifically, part no. G5V-2-H1-DC12) is appropriate for this application? I like this DPDT relay because of its size, price and the fact that a mounting base is available (part no. P6B-04P), but don't know if there is something better suited for line level signals.
Many thanks,
Scott
Old 31st January 2009, 01:41 AM   #2
The company I work for has been using this Omron part for many years for switching audio and video with no problems. I remember once they tried to switch to a lower cost Fujitsu part. We found in the production line that it had problems switching audio at low levels. We noticed that there is a spec called "minimum permissible load". The Omron is 10uA at 10mVDC, where the Fujutsu part was much higher, if I remember correctly 100mA at 10mVDC. This is a spec I will forever look at very carefully.
Old 31st January 2009, 09:03 PM   #3
SRMcGee's Avatar
raudio1969:
Many thanks!
Scott
YET another relay attenuator question robmil Solid State 0 14th April 2008 05:44 AM
Newbie Relay Question SRMcGee Parts 13 13th November 2006 02:54 AM
switch or relay question! plz help jaygeorge1979 Parts 6 26th April 2006 01:16 PM
switch relay question jasong Parts 2 5th May 2005 06:42 AM
Page generated in 0.06023 seconds (73.16% PHP - 26.84% MySQL) with 10 queries
