| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Am I going crazy?? I have a 36 volt center transformer,. So I should had 2 18 volt ac output right?
But for some reason I measure 21 volt ac on each output? Can some shed some light this for me, and by the way this the 3 one I have tried 2 of them were used. Lost |
#2 |
You are measuring "no load" voltage. If the transformer outputs its rated current, the voltage will drop from no load voltage. Also, your mains supply may have a higher voltage than what the transformer specifies for its rated output.
| Transformer question? | mcameron | Parts | 5 | 23rd January 2005 07:52 PM |
| transformer question | xcortes | Chip Amps | 0 | 31st October 2004 05:04 AM |
| Transformer Question | TunaFish | Tubes / Valves | 15 | 18th June 2004 11:20 PM |
| Transformer Question | toque_101 | Chip Amps | 2 | 26th January 2004 05:21 AM |
| Page generated in 0.06970 seconds (65.84% PHP - 34.16% MySQL) with 10 queries |
