Carrier Current AM Radio transmission - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th April 2003, 06:35 AM   #1
akersa is offline akersa  United States
Default Carrier Current AM Radio transmission
I just got done building a tube am radio transmitter with two 6L11's and I have been doing some reading on Carrier Current circuits. From what I understand the RF signal gets injected onto the power cable, and then as long as you are close to the outlet or wire in the wall your radio can pick it up. However I can not find schematics anywhere as to how to build such a circuit, and I am afraid to just try anything, for fear that I will burn out my transmitter. Please Help!!!!
thanks,
Adam
Old 13th April 2003, 12:51 PM   #2
Circlotron's Avatar
Here's a National Semiconductor app note for a low power FM one, but I expect similar principle would apply.
http://www.national.com/an/AN/AN-146.pdf#page=1
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 13th April 2003, 03:57 PM   #3
paulb is offline paulb  Canada
I've often thought about building this one. The problem was the line isolation transformer. Anyone have ideas on something readily available that would work?
Gain Module with Current Transmission Technology audio-gd Solid State 3 16th September 2013 08:34 PM
people carrier sounds NED 209 Car Audio 3 31st December 2008 12:11 AM
Adding a 38kHz carrier to IR rtarbell Digital Source 5 7th July 2006 09:14 PM
amp picks iup radio transmission h_andree Chip Amps 4 10th December 2005 11:30 PM
Copyright 1999-2017 diyAudio
