Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th January 2009, 08:41 AM   #1
Default Strange resistor color codes
I opened an old CD player and came across these strange resistors which have 5 color bands:
white-gold-gold-blue(violet?)-green
on light green background.
(black circled on image)
They just don't make sense, do they?
By the way I found all the diodes of the bridge bypassed with 22 nF ceramics: I believed this solution was only typical of DIYers! (red circled)
Old 17th January 2009, 09:03 AM   #2
Geek's Avatar
They are probably inductors.
http://www.elexp.com/t_induct.htm
Cheers!
Old 17th January 2009, 09:04 AM   #3
raindog is offline raindog  Romania
raindog's Avatar
Send a message via Yahoo to raindog
Indeed very strange ( gold is usualy used to indicate 5% tolerance ); I guess the simplest way to determine the value in this case is to take one out and measure it . By the way bypassing rectifier diodes it's common practice in electronic equipement ( DIY didn't invent electronics , we just try to use the best technical solutions available )
Old 17th January 2009, 09:05 AM   #4
Hmmm, sounds strange because they are marked Rxxx on the PCB...
BTW they get quite hot while the cd player keeps seeking (in fact they are a bit elevated from the pcb)
Old 17th January 2009, 09:06 AM   #5
Geek's Avatar
OK, then they are low ohm resistors, probably military types.
I couldn't see the designation from the pic.
Cheers!
Old 17th January 2009, 09:46 AM   #6
Could they be small value inductors?
Help needed with reading resistor codes (Brian's LM3875 kit) maurycy Chip Amps 3 19th March 2006 12:56 AM
Sprague/Cap Color Codes ? Trout Tubes / Valves 4 13th August 2005 04:06 PM
resistor colour codes fezz Parts 7 5th February 2003 08:40 PM
Color codes on transformer Anders DK Solid State 10 29th October 2002 04:29 AM
Page generated in 0.06909 seconds (79.52% PHP - 20.48% MySQL) with 11 queries
