Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th January 2009, 02:51 PM   #1
Default Connecting a voice recorder to AUX
Hi!
Is it possible to connect output of AUX to the input of a voice recorder?
The input was previously connected to a microphone but I want it to be connected to the amplifier system output so that I can record the music output from the amplifier system.
The input impedance of the voice recorder is 2KOhms. I am using an Olympus VN-2100PC voice recorder. I am not sure of the output impedance of the AUX.
thanks.
Old 16th January 2009, 10:14 PM   #2
Steerpike's Avatar
AUX is usually in INPUT on amplifiers.
You probably want to use the connector marked "TAPE REC", and you MAY need to add a series resistor or two, particularly since the voice recorder is likely mono, and you need to blend the two stereo outputs of the amplifier.
A pair of resistors of 20k to 50k - one from each of L (hot) and R (hot) and common connected to the MIC (hot), ought to work.
protron dvd recorder steven344 Solid State 0 24th November 2008 07:44 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
How do I use computer CDR's in my CD recorder? Gretsch6136 Digital Source 11 18th September 2006 09:13 AM
My Sony DTC-690 DAT Recorder richardsymes Digital Source 6 23rd July 2006 12:29 PM
vinyl recorder sss Analogue Source 0 30th May 2005 10:38 AM
Page generated in 0.07321 seconds (71.69% PHP - 28.31% MySQL) with 10 queries
