| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Really simple question I've had surprisingly little luck getting the answer to from google:
What are the sort of voltages you can expect from a photodiode operated in photovoltaic mode? |
#2 |
the photocurrent forward biases the PN junction, flowing thru it in an internal loop following the ideal diode/shockley diode formula
for single crystal Si you might get .3 -.5V depending on illumination, light wavelength, temperature... for linear measurement the photodiode is usually connected across the input of a transimpedance amp that holds the V to 0 so all of the photocurrent flows through the feedback R you can get an optoisolator that stacks photodiodes in series to generate enough V to turn on a MOSFET |
#3 |
But such voltage would be with picoamps of current (common diode). Even a DMM would load it down to a few microvolts if you tried to measure it.
Cheers! |
#4 |
Taking into account everything just said, I find it odd that I've been able to measure 1.2V from a normal red LED lit up brightly
#5 | |
2012, our time is running out. |
#6 |
Well now I have found a fun floating bias source for MOSFETs without using batteries or expensive photovoltaic optocouplers
#7 | |
#8 |
Time to change my speaker cables to optical fibres and my amp to a modulated laser!
#9 |
Regarding LEDs, I would use the exact same types for both the source and receiver
#10 |
I have actually used LEDs for a floating bias supply.
Figures a and d work in the real world. The other figures are just wild lateral thinking on my part. Probably not practical. http://tinyurl.com/8wpwzl Cheers. ZAP |
| Current Mode Control And Voltage Mode Control | jegandren | Power Supplies | 4 | 26th February 2008 08:26 AM |
| Fully differential opamps and common mode voltage | rtarbell | Solid State | 1 | 15th August 2006 07:13 AM |
| Voltage Mode Pre and Post Filter Feedback | Genomerics | Class D | 30 | 6th April 2006 07:27 PM |
| Current Mode vs Voltage Mode | G-Daddy | Solid State | 11 | 27th March 2002 06:11 PM |
| Page generated in 0.17254 seconds (43.86% PHP - 56.14% MySQL) with 10 queries |
