Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
HELP "extra" sound problem on DIY pcb
Old 11th April 2003, 08:55 PM   #1
Cwolde is offline Cwolde  Netherlands
Default HELP "extra" sound problem on DIY pcb
Iv'e constructed my own 24dB LinkwitzRiley 2way active crossover, you can see it here pcb
And put it in a pre amp, which you can view here setup
It's set to 300 Hz. Below 300 it sounds fine, above it, it sounds fine for about ten seconds, then starts this sissing sound, as if a tire were running flat. Is this oscillating? Electrolytic connected the wrong way?
I did decouple the OPA2604's between V+ and V- with 100nF ceramics.
It's on both channels and starts at the same time. With louder volume it's not noticeable but at level 0 its really there and annoying ofcourse.
Any suggestions about what is causing this???
pro active!
Old 12th April 2003, 10:19 PM   #2
guido is offline guido  Netherlands
guido's Avatar
Maybe you need to put the 100nF direct on the pins, it could be that they are too far away from the opamp pins!
Good luck,
GuidoB
GuidoB
HELP "extra" sound problem on DIY pcbHide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
How to get rid of "CKK" Sound on "turn off" riotubes Parts 0 25th November 2006 03:50 PM
"lift off " or "Houston we have a problem" tenderland Tubes / Valves 16 1st May 2005 05:08 PM
