Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th January 2009, 02:50 AM   #1
mjk130 is offline mjk130  Australia
Default Help identifying a pair of output transformers and power transformers
Hi I recently bought a pair of output and power transformers for an amp project but have had no luck what so ever finding specifications on them.
P-6417-6066453 out put transformer
P9416-1 10525644 power Transformer
Those are the identifying codes; if anyone has any information on them I would greatly appreciate your help.
Thank you all for your time.
Old 15th January 2009, 07:55 AM   #2
impsick is offline impsick  United States
impsick's Avatar
some pics, mfg. name, and any other numbers on them might help
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 15th January 2009, 10:39 AM   #3
Geek's Avatar
Those are house numbers and data died with the manufacturer most likely. I have a mate with a basement full of those and the only way to reliably get the spects is to measure with sample voltages and loads.
If you knew what type of output tube was used and if they are PP or SE, this could be pretty painless
Cheers!
Old 30th January 2009, 11:44 AM   #4
Send a message via AIM to nania
I am in a similar situation. Geek is correct in stating that searching the part number is probably fruitless. Most transformers are built to accomodate a series of products and are marked for in house use. Once that product is defunct you won't likely find any spec on it. There are several things you can do to get in the ballpark:
1. Measure the physical dimensions. Knowing the weight and size will help gauge the approximate power capability and regulation.
2. Spec the input and output wires. This will help approximate the winding, the likely regulation spec and its current carrying capabilty.
3. Feed the primaries and measure the unloaded outputs. This will help confirm the winding and give you the output spec.
4. Identify the core material. This will help determine the ratio of core to wire which will give hints about the regulation spec and approximate the permeability curve. All of these will give hints about the max operating temperature.
I have done these on a pair of unidentified matched transformers and discovered that they have a 3:1 knockdown with 120/240 inputs with a conservative 250VA rating for each. I was thinking of using them to build an integrated pumpkin/F5. Am I likely to run into any problems using both inputs and ouputs simultaneously to power this integrated? I know this is slightly off topic but I thought I'd mention it here before starting a new thread on it.
Identifying Stancor Power transformers bereanbill Tubes / Valves 9 25th April 2009 08:52 PM
FS: Edcor GXSE15-8-5k Output Transformers Brand New Pair nic6paul Swap Meet 2 12th April 2009 09:55 PM
Power Transformers in Output! mod_evil Tubes / Valves 17 25th May 2006 09:31 AM
FS: pair of ORIGINAL Sansui au-111 output transformers Mark Hathaway Swap Meet 0 8th March 2004 01:02 PM
FS: Pair Hammond 125ESE single ended output transformers Saurav Swap Meet 3 28th August 2003 07:44 PM
Page generated in 0.09271 seconds (72.12% PHP - 27.88% MySQL) with 10 queries
