binding posts - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th January 2009, 10:55 PM   #21
frugal-phile(tm)
planet10's Avatar
Default Re: These are very good and cheap
Originally posted by badman
Best @ Apex
One trick is to not solder to the post, but rather, run the wire out through holes next to the posts and use the posts as a compression terminal to clamp the speaker cable to the output leads. Bypass the post nearly entirely, for simplest path.
Yes those are the ones i'd choose. The using the binding post is a good trick that i've know for some time... when i get a system well and truly set in place i actually use it...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th January 2009, 11:10 PM   #22
MJL21193's Avatar
Originally posted by planet10
I gots lots of those -- cost = $0.00
Used?
I prefer banana jacks:
kef 107 binding posts dayking79 Multi-Way 1 1st September 2008 11:47 AM
Binding Posts ANDYLASER Swap Meet 7 23rd November 2006 11:33 AM
Binding posts cp642 Parts 6 16th November 2001 02:10 PM
Copyright 1999-2017 diyAudio
