Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th January 2009, 07:08 PM   #1
Default 150/600 Isolation Transformers- any uses for hifi projects?
I've got a bunch of v. good quality line isolation transformers, and need some ideas of how to use them in audio projects. (Components driving choice of project...)
Transformers (Hammond 850G) have 150/600 primary, 150/600 secondary. 20Hz-20kHz +- 0.5dB.
My audio setup now is CD player into tube amp (Pointz 6V6 MM), but I plan to build up some chipamps and perhaps a preamp like the Pass B1 at some point.
Can these be used in interstage or input locations, in place of a capacitor? All the stuff I've found on transformer coupling seems to have high impedance secondaries.
Or should I just try to sell these to somebody who's making a mic/recording setup?
John
Old 11th January 2009, 08:19 PM   #2
Sjef is offline Sjef  Netherlands
One thing you can do with them is to drive the preamp output into them, then put another pair on the power amp input and terminate it with 600Ohms and then you will have a perfect transmissionline between your pre and poweramp wich can be over 100 meters long if you want. Welcome to the world of Pro-Audio
4kV isolation input transformers? mzzj Parts 2 24th July 2005 09:11 PM
Isolation transformers Bricolo Parts 36 28th June 2004 07:46 PM
need help with audio isolation transformers azira Parts 9 18th June 2004 09:44 PM
Isolation transformers Lo-z to HI-z Roadking Swap Meet 0 5th April 2004 12:05 AM
Using isolation transformers with TT motors? Saurav Analogue Source 6 13th February 2003 06:16 AM
Page generated in 0.06195 seconds (68.35% PHP - 31.65% MySQL) with 10 queries
