Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th April 2003, 11:47 AM   #1
Default High inductance inductors
Hey there everyone,
I decided to join up here since my frustration at the lack of information of this topic on the web is growing at a rapid rate.
I need a 1.5 henry inductor (I know it sounds massive, but it's right for what I want to do) and I can not find a single place on the net that even makes them, let alone sells them. It's for a low voltage circuit, basically I want to convert the tone pot of my guitar to a mid-range, and need one to go from the left tab to ground.
Anyone have any idea who I could get a small number (no more than five) from?
Thanks,
Daniel
Old 10th April 2003, 08:06 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
What kind of current does it need to handle? Chokes up to and past 100 henries are common in tube amps.
I'm guessing small signal, that might be a little harder to find these days. Might be able to find a 10mA or so choke though.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 10th April 2003, 08:20 PM   #3
Would this be what you're looking for:
Hammond Chokes
Dan
Old 12th April 2003, 08:25 AM   #4
Dantwomey-
Right amount of inductance, but the current handling is too high.
I think the maximum output of my pickups is less than a volt; so I guess the current handling would be *line level*.
Old 26th April 2003, 06:59 PM   #5
Default inductor
Dont know... but it seems to me that you are looking for somthing like : http://www.geofex.com/
search for the wahwha...The Technology of Wah Pedals
Version 1.7 9/27/99
Ive used some different "transformator" (use just one side of the transformator) to get what I searched for.
hope this helps
björn
Old 27th April 2003, 01:36 AM   #6
jackinnj's Avatar
Default if its for a low current ap
you can use a high permeability torroid and wind it yourself
Old 27th April 2003, 11:20 AM   #7
To wind a "torroid " as jackinnj suggested I thik would be hard, maybe he ment a ferritcore. Look it up in any eletronic supply cataloguge and see how many windings you need, but I think it would be something like 700 (or in that region)
What you need is 2 halfs of core and a boobin and copperwire (insulatet) and a small handdriven drill. The diameter of the Cu-wire depends how much losses you can accept (you'll wind up with a wireresistor ) But for your purpose take the cheepest ( somthing like a #35 or 0,1mm....
If you dont find any give me a mail I I see what I can do.
björn
Old 27th April 2003, 11:53 AM   #8
Circlotron's Avatar
Default Re: if its for a low current ap
That'd work fine (no hum pickup either) but I think it would be a job only suitable for visitors to purgatory I wound up a 1.2 Henry inductor on an ETD34 core a few weeks ago and it needed about 800 turns IIRC. It has a bobbin though so that makes it really easy. That's my choice.
Ah, gammelmalle. I didn't refresh the page before I posted so I didn't see your post.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Hgh inductance, high impedamce speaker cable starburst Multi-Way 17 4th February 2009 03:09 AM
Wanted: Inductance meter, inductors. Spasticteapot Swap Meet 14 30th October 2007 02:18 PM
Where to get - Very high quality inductors? Tenson Multi-Way 5 27th August 2006 11:33 PM
Good Source for high current Inductors?? Zero Cool Pass Labs 5 13th November 2004 11:36 PM
Page generated in 0.08981 seconds (77.86% PHP - 22.14% MySQL) with 10 queries
