| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hye all,Hapy New Year to all of you.
Im looking for volume control IC similar application with DS1666/DS1669.Im unable to find any DS1666 supplier in my country. Thank in advance. |
#2 |
Hello elnino86,
Try the PGA2310, PGA2311, and PGA2320 from Texas Instruments. I don't know what your application is exactly, but any digital potentiometer with a LOG taper (or LOG scale) should be okay for an audio application. The PGA series from Texas Instruments is probably one of the best "suited" for audio applicaitons because of their bipolar outputs (when used with dual power supplies) and their very good noise and THD measurements. |
#3 |
If you want to make pre-amplifier with volume controller, then I think it is recommended to use BB's product(PGA2310, PGA2311, Etc). These has different power range so that If you explain the a little information, then you can be recommended one of them.
I'll show you my work. This support the balanced input and output with unbalaned mode. ^^It controlled by remote controller and rotary encoder..Even it is controlled by USB-based PC Software. |
#4 | |
Recommended by whom? These chips are only for the fans of cheap opamps. DS1666 sounds much better. It's not available in my country either but fortunately DigiKey ship anywhere. |
#5 |
Dun fight.
Thanks for advice but i dun think the TI stuff is easy to design.I just need some simple push button and voltage supply.
#6 | |
Oh, Really? DS1666 is better? Hmm.. I didn't used DS1666 yet, But I'll try. Thansks. ^^ |
#7 |
elnino86,
I could possibly send you a few DS1666. What value do you need; 10k, 50k, 100k? DIP or SOIC? Are there any kind of shipping restrictions from the US to Malaysia that you know of? I also have some extra boards for a very small and simple PGA2320 volume control. This does require a dual supply though.
"If you don't like funerals don't kick sand in ninja's face." |
#8 | |
But,it didnt work at my design.I use 2 push button to increase and decrease the volume.can you help me a little bit here? |
#9 | |
I was going to mention that I don't think the DS1666 can even be operated by push buttons. It needs a controller. The DS1669 uses push buttons, but this is a linear digital pot and not a pseudo log like the DS1666. Take a look at the DS1802, MAX5486, and MAX5456/7.
#10 | |
I need 10k.Im already use DS1666.Now i need a pseudo log like DS1669.But i dunno how to interface it. DS1802 look fine for me but it build with 45k ohm.MAX5486 n MAX5456/MAX5457 only built in SOIC. |
| digital volume control | neazoi | Parts | 1 | 21st April 2009 09:56 AM |
| Digital volume control | maharadza | Digital Source | 9 | 8th April 2006 05:59 PM |
| digital volume control | Pulse-R | Digital Source | 4 | 5th April 2005 02:33 PM |
| Digital Volume control for in Car use | dunderchief | Digital Source | 7 | 28th March 2004 01:08 AM |
| Using a pot to control a digital pot | Bill Fitzpatrick | Digital Source | 4 | 23rd March 2004 09:25 PM |
| Page generated in 0.11106 seconds (78.95% PHP - 21.05% MySQL) with 11 queries |
