| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Recently I scored a pair of White Instruments 4391 output transformers. These were meant as an add-on to one of their products (a graphic equalizer, I think). Does anyone out there have any information on these?
#2 |
I have a White EQ and these are used to couple from the standard 600 ohm required loading to other loads like a typical audio input of 100,000 ohm or 50,000 ohm.
I might want to buy if you can let them go cheap. Don't need them yet, but they might come in useful some day. |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| White instruments model 2570 | Original Burnedfingers | Equipment & Tools | 1 | 27th November 2007 12:21 PM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 07:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 06:17 AM |
| Experiences with White CF/CCS CF output stage | mashaffer | Tubes / Valves | 50 | 1st August 2004 04:42 AM |
| Page generated in 0.05929 seconds (69.78% PHP - 30.22% MySQL) with 10 queries |
