| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi.
I wanna build a simple line level summing device for use in my guitar rack. Now, I've read that you can just put resistors on the hot leg of each input, but also that this causes attenuation and might cause channel bleed. From what I understood you could use op amps instead. How would these be connected in a simple 2-1 mixer? Also, is this possible to do with 9VAC? |
#2 |
Check out "Figure 2" at the link below for a simple op-amp based mixer.
http://sound.westhost.com/project94.htm
"If you don't like funerals don't kick sand in ninja's face." |
#3 |
Ah, got the same tip from another site.
How do I get rid of that master volume, just skip it and put a connection between R116 and R117? |
#4 |
No, just leave out VR104 and R117, but keep the R116 output resistor.
| Simple discrete unity gain buffer | tcpip | Solid State | 111 | 7th June 2007 06:55 PM |
| line level modular mixer? | post78 | Analog Line Level | 0 | 21st February 2007 09:55 AM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 02:30 PM |
| A Heretical Unity gain line stage | SY | Tubes / Valves | 85 | 22nd June 2005 12:37 PM |
| Page generated in 0.05895 seconds (80.50% PHP - 19.50% MySQL) with 10 queries |
