Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Ground field on pcb - how to connect ?
Old 28th December 2008, 04:00 PM   #1
GrzMiL is offline GrzMiL  Poland
Default Ground field on pcb - how to connect ?
Hi
I have a short question and answere is probably very short too.
I've used the serch button but found nothing.
I'm not sure if "ground field" is technical term so what i mean by this is an area of copper on PCB connected to gnd.
And question is:
Should I connect this field to GND only in one point as in the upper part of a picture OR let the field be connected to the GND in every possible place - this means it is one big GND trace - as in the lower part of the picture
It would be nice if someone gave a link to an article or something about ground fields.
Thank you
Old 31st December 2008, 03:17 PM   #2
jitter is offline jitter  Netherlands
jitter's Avatar
Google using "ground plane". A very short explanation can be found here, but there's more to be found.
In your example, there's not really a difference. The differences will be big(er) when you're dealing with multiple circuits that are not close together and/or using different grounds (risk of creating ground loops). Also google using "star grounding".
Good luck.
Old 31st December 2008, 06:01 PM   #3
Thanks for replay
I was looking for "ground field"... :/
I know that in this example there is no difference, i made this "board" just for example, but I've almost finished 10 x 4 inch board with active filters and on that bord it will probably make a difference.
Happy new year !
Ground field on pcb - how to connect ?Hide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
StarGround: where connect the ground pin of the Volume Pot ygg-it Chip Amps 1 19th May 2008 12:55 PM
connect to circuit with different ground level jegandren Power Supplies 3 23rd April 2008 02:42 AM
Chassis, ground, earth: connect? starbase218 Solid State 3 14th November 2007 08:56 AM
How to connect ground plane to via using Eagle? Ipanema Everything Else 5 23rd October 2006 08:16 AM
