Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Long RCA Jack for wooden enclosure?
Old 22nd December 2008, 08:50 PM   #1
vonfilm is offline vonfilm  United States
Default Long RCA Jack for wooden enclosure?
Where would I find a good source for reasonably priced longer rca jacks and binding posts for a wood enclosure. I need to find a longer DC jack also.
Old 22nd December 2008, 10:12 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Just use a flat bit or forstner bit to create a hole with the proper panel thickness.
Old 22nd December 2008, 10:38 PM   #3
Cloth Ears is offline Cloth Ears  Australia
Cloth Ears's Avatar
Try these Neutrik NF2D-B-9's instead. You simply make your hole 23.6mm (0.93") and you've got plenty of room to work with. And added advantage is that they're level with the back panel, so no chance of knocking them.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 24th December 2008, 03:48 PM   #4
Those Neutrics look interesting, but where do I find a 23.6mm(.93) Forstner bit? Why didn't they make it 7/8" or 1"?
Old 25th December 2008, 07:47 AM   #5
dangus is offline dangus  Canada
Other options:
- use a router to create a recess
- cut a hole and mount the jacks on sheet metal or PC board stock. Screw and RTV it in place.
- Order a metal or plastic terminal cup that screws into a hole and provides a recessed mounting location for jacks and binding posts. MCM & Parts Express should have them. Some come prepunched for popular audio connectors.
Switchcraft makes (or made) some very long 1/4" jacks, but I don't remember ever seeing a comparable RCA jack.
Old 25th December 2008, 08:53 AM   #6
DimZ is offline DimZ  Greece
take a look at this , thats what i'm gonna do with my wooden enclosure , just beautiful
http://oldheadphones.com/crystal/info/tubeamp.htm
Old 25th December 2008, 10:13 AM   #7
if 1.5" long stem is good for you
http://cgi.ebay.com/GOLD-PLATED-SPEA...QQcmdZViewItem
also has the neutrik rca
Old 29th December 2008, 04:42 AM   #8
Corvus corax is offline Corvus corax  United States
Cardas makes some longer RCA jacks as well. Can't remember how deep they go off the top of my head, though. Something like 1/2 inch.
Old 29th December 2008, 04:54 AM   #9
Aengus is offline Aengus  Canada
Aengus's Avatar
Well, if you use a 1" bit you'll have a clearance of just under a millimeter all around, which I'd regard as reasonable for working in wood. If you want tighter tolerances, a 15/16" bit (if you have one) would give you an order of magnitude less clearance, which I personally wouldn't find necessary: YMMV, of course.
Regards.
Aengus
Old 29th December 2008, 06:22 PM   #10
Aengus,
I am sure you are right about the drill bit size for the Neutrics.
Everyone who answered my inquiry here had some great ideas that I would like to try in the future.
On Sunday, I got out my Dremel tool and inletted the rca jacks and stepped ladder attenuators into the wooden cigar box that I am using for the case to my B1 Pre-Amp. You can see pictures of it there in posts #1018, and #1019. It was a lot more work but I was able to use the parts on hand.
http://www.diyaudio.com/forums/showt...53#post1697753
http://www.diyaudio.com/forums/showt...55#post1697755
Long RCA Jack for wooden enclosure?Hide this!Advertise here!
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 04:39 PM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 03:16 PM
My new wooden gainklone DT Chip Amps 8 6th August 2005 03:09 AM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 11:53 PM
Copyright ©1999-2017 diyAudio
