Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
questions for crossover parts
Old 19th December 2008, 10:21 AM   #1
hotblade6 is offline hotblade6  Sweden
Default questions for crossover parts
For a while, i have been trying to make the crossovers for zaph's sr71
http://www.zaphaudio.com/SR71.html
For the record, i'm going to use them with a revox A50(40w+40w)
I could not find conductor of 1.5mm(close to 15AWG) in the local market so i had to use 1mm with the cost of a little higher resistanse(the 3.3mH coil riched the 0.5ohm).Am I going to have noticable amp power loss?And how could i be sure that tha 1mm conductor can handle power without heating problems?
What kind of capacitors?should all of them be poly?And further more what voltage should they handle?
thanks alot
(the inductor in the photo :3.3mH 0.5ohm.Any comment?)
Old 20th December 2008, 12:42 AM   #2
what does the symbol for the thread with the black dot means?
Old 20th December 2008, 12:58 AM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Your inductor will handle the power, no problem
The higher impedance should idealy be taken into acount when calculating size of enclosure, but all you may notice is probably a bit more bass level and maybe a bit less controlled, but maybe you wont notice much difference, and if you are lucky it could actually be better
Capacitors should all be poly as the biggest is 40uf and neither hard to get or expencive
I havent handled that many caps, but I think 250V is a common and sensible value, at least thats what I use
You have 3 inductors so you must mount carefully with the right orientation and preferably not too close to each other
its very common to try and connect the components directly to each other with the result of a very compact and messy layout, which is a fault and is easily done wrong
Mount exactly like Zaph shows
there is nothing wrong in using a bit of solid core wire fore the connections
http://www.troelsgravesen.dk/coils.htm
btw, its very good to have a seperate earth wire from the terminals to each drivers crossover section, and please use solid core
sometimes we know very little, and sometimes we know too much
Old 20th December 2008, 01:19 AM   #4
thank you for the reply!
Old 20th December 2008, 01:52 AM   #5
A small tip
I believe you can get Monacor parts in Greece
Their oval silver coulered axial poly(MKT) capacitors are quite good and not too expencive
questions for crossover partsHide this!Advertise here!
Where to Purchase Crossover Parts samsagaz Parts 17 12th February 2009 12:35 PM
Crossover Parts Timn8ter Swap Meet 4 1st December 2008 06:52 PM
Help with crossover parts..... audiokid25 Multi-Way 0 25th July 2005 09:38 PM
Parts for this crossover The Paulinator Multi-Way 4 13th April 2005 04:10 PM
Crossover parts??? Per Nielsen Multi-Way 4 16th March 2003 03:05 PM
Copyright ©1999-2017 diyAudio
