| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello,
I have a circuit with LM337T and LM317T, they output -24 volts and +24 volts in the circuit. Now, I am considering upgrading these regs with the LT337A and LT317A. If I drop these into the circuit, do the adjusting resistors stay the same? IE does the new regs still output -24V and +24V without any changes? As another option, how would the LT3080 integrate into my circuit? Is there a negative voltage equivilant to the LT3080? Thanks |
#2 |
They should be equivalent same and replaceable.
Each devices, even if replacing one LM337T with LM337T, can have a very slightly diff reference voltage. 1.245 vs. 1.239, for example So give or take a few 0.1%, which in most ciruits fed will have no practical issue.
lineup |
| Symmetric PSUs and negative voltage regs | hollowman | Power Supplies | 1 | 7th August 2009 01:57 PM |
| Generic snubber values: fixed-/variable-voltage regs | hollowman | Power Supplies | 44 | 28th April 2008 11:09 PM |
| Low noise voltage regs | Extreme_Boky | Digital Source | 3 | 17th May 2007 06:34 AM |
| LM385 Adjustable voltage ref. diode as LED bias? | mus | Tubes / Valves | 2 | 30th March 2007 05:27 AM |
| Amplifier with LM317/337 voltage regs. | DigitalJunkie | Solid State | 1 | 20th January 2005 12:36 PM |
| Page generated in 0.06510 seconds (67.85% PHP - 32.15% MySQL) with 10 queries |
