Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Ordering Service Manuals on line.
Old 16th December 2008, 12:02 PM   #1
sonicgrail is offline sonicgrail
Default Ordering Service Manuals on line.
Hi guys ,i have was wondering if any one has any experience with (Manuals in pdf.com). I want to order a service manual for my JVC RX-888VBK.....The display is blank (but I can still select inputs and the volume works.)
I figured that the low voltage A.C is missing so the Vaccum display has no heater voltage ,therefore no dispaly.
I would be very happy to hear about your experiences ,when it come to buying service manuals on line
Thanks guys!
Old 16th December 2008, 12:08 PM   #2
Mooly's Avatar
That should be easy to trace. Are you 100 % sure it's missing. Can you feel the display warm. Can you see the filaments lit in a totally dark room ?
Old 16th December 2008, 12:11 PM   #3
Mooly's Avatar
The filament pins are the end ones and usually sit at around negative 25 volts going from memory. Not familiar at all with your model but most problems are small electroylitics that dry up causing the negative rail to disappear. Are there any negative voltages on the display pins, run a meter down them all !
Old 16th December 2008, 12:13 PM   #4
Mooly's Avatar
One other thing, some designs derive all these voltages from a small HF invertor, again it's always caps that fail doing the damage. If the heaters are from an HF supply a DVM won't measure them properly.
Old 17th December 2008, 01:28 PM   #5
Thanks Mooly! ,for you help ...I took the plunge and bought a manual then i spent some time on my Rx-888 .I traced the heater voltage to a connector on the transformer board ,there was 5 .6 volts A.c on 2 of the 0.22ohm resistors but on the connector it was missing.I traced the fault some open circuited print that was near the other leg of the resistor that is connected to pin 33 of the transformer.
Yes!!!!! I feel Great !! I felt a but sucky because i bought the manual ..but now I see that it is better to invest in a good schematic diagram (service manual) instead of trying to hunt around for a problem (regardless of how simple the fault was ) I`ve got that SWEET feeling again ..now I want to get back into repairing more equipment!!!!!
Old 17th December 2008, 03:32 PM   #6
Mooly's Avatar
That's great news. A service manual is always a good idea anyway, they always come in handy
Old 17th December 2008, 04:21 PM   #7
PH104 is offline PH104  United States
PH104's Avatar
I recently ordered a pdf service manual from servicemanuals.net. No problems & I would use them again. The pdf manual was nice since I could zoom in on parts of the schematic and print out the zoomed section.
Funny thing......... I just got done fixing a piece of equipment that would a bad fluorescent display for a friend.
Ordering Service Manuals on line.Hide this!Advertise here!
Free user manuals, service manuals, brochures, schematics, pictures, audio, video, ph notka Swap Meet 1 23rd October 2011 04:27 PM
looking for service manuals nunoit Car Audio 0 13th April 2009 05:21 PM
Service Manuals On-line jkeny Everything Else 43 19th April 2008 11:38 PM
how about service manuals deji Everything Else 0 16th March 2004 02:02 PM
