Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th December 2008, 12:32 AM   #1
wigginjs's Avatar
Default Power conditioner / isolation transformer
I just purchased a couple of power conditioners by "OneAC" (model #MD1170 which I understand is equivalent to PCM750A). When I look inside basically all I see is a big switch, a HUGE transformer, and a small board with some poly caps on it connected to the receptacles. I measured the voltage coming out of my wall and it was ~122.5VAC. Then I measured the VDC and it swung between -0.3 and +0.3. Now when I measure the voltage THROUGH the conditioner I see ~126VAC and a swing between -0.1 and 0.1 VDC. I've got two identical units and they measure the same.
Questions:
1) Huh? I thought this was supposed to regulate the voltage?
2) Do these provide surge protection at all?
The Four Chairs
DIY Home Theater
Old 16th December 2008, 12:07 PM   #2
power conditioners are usually used to remove some of the interference that accompanies the mains waveform.
regards Andrew T.
Power conditioner / isolation transformer wigginjs Solid State 3 18th December 2008 03:30 AM
UCD as power conditioner Daveis Class D 3 28th October 2006 09:39 AM
DIY power conditioner? leadbelly Power Supplies 8 14th March 2006 04:09 PM
power conditioner diram6 Power Supplies 0 2nd December 2005 05:10 AM
power conditioner diram6 Parts 0 2nd December 2005 04:06 AM
Page generated in 0.05629 seconds (79.42% PHP - 20.58% MySQL) with 10 queries
