Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th December 2008, 03:45 PM   #11
jneutron's Avatar
Of course it makes an audible difference.
Sheesh, why ask such a silly question...
Ok...parameters.
1. 30 pf per foot.
2. Dielectric coefficient 2.7 for teflon
3. Inductance per foot:
LC = 1034 DC
L = 1034*2.7/30
L = 93 uH per foot.
4. Z = sqr(L/C) = sqr(93000/30) = 55.6 ohms
5. Prop speed = 1/sqr(DC) = 60 % lightspeed
characteristic impedance..55 ohms. (hey, about 30 pf per foot is gonna give about the correct Z. This is the characteristic impedance without consideration of the core material. This will be the microwave prop velocity.
Ok, now for the steel core..assume it has a permeability of 100 (WAG)
L = 9300000
Z = sqr(9300000/30) = 556 ohms.
Until skinning occurs, the characteristic impedance of the cable is 556 ohms. As a matter of course, the characteristic impedance of the cable will track directly the permeability of the core material. If you use a steel of permeability 1000, the cable Z will be 5560 ohms..
Now, use one of these as an IC...bah, I'll post a link, put the numbers in and see where the break frequency is for the shield current..
http://www.diyaudio.com/forums/showt...22#post1672822
Just substitute the inductance of a typical length into the model instead of the .5 uH, use 6 feet of 9300 nH per foot, or 55 uH.
Fun stuff.
oops..forgot prop speed at audio frequencies..
EDC = LC/1034 = 269
prop = 1/sqr(269) = .06 C...6% of lightspeed..
Sheesh, whatta snail..
Cheers, John
Air or a steel core inductor Jonasa Multi-Way 20 1st December 2010 04:08 AM
Unwinding a steel laminate core inductor? Formula? AudioLapDance Parts 1 18th February 2009 01:27 AM
Grain oriented silicon steel core data needed eppidei Tubes / Valves 0 14th September 2007 02:08 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers Workhorse Solid State 13 23rd January 2004 09:14 AM
Page generated in 0.06549 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
