Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
digital volume control
Old 8th December 2008, 07:34 AM   #1
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Default digital volume control
anyone implimented a digital (or other SS) volume control in their tube amplification? I'm thinking it would provide a relatively simple and clean faceplate solution and easily interface with remote control. Especially like the look of the IC based solutions eg Maxim or similar. Comments please.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 8th December 2008, 08:41 AM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
DS1666 with push buttons. About to do it with a rotary encoder.
Not as bad as i anticipated. Better than cheap pots and at least no opamps inside. Should be easy to integrate a remote. And ARC uses it in their REF preamps.
Old 8th December 2008, 12:02 PM   #3
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
6 relays, 12 resistors, one uln2001 and a microcontroller. gives 64 steps and I've picked the resistors for 1 db steps. Could easily change the attenuation per step and increase to 128 or even 256 steps if I wanted. Microcontroller is a BasicX24, but could be a pic instead. gonna use buttons for vol up and down, but could easily use a linear variable resistor connected to the microcontroller ADC to adjust volume too.
Old 8th December 2008, 12:10 PM   #4
SRMcGee is online now SRMcGee  United States
SRMcGee's Avatar
aardvarkash10:
Do you mean like this? This is an Aikido preamplifier (preamp on the left, power supply on the right) with a Dantimax remote control system.
Scott
Old 8th December 2008, 06:59 PM   #5
Default thanks guys
very nice solution scott - sorta raises the bar on my expectations! Yeah, I aslo considered relays and resistor networks, but it seems a lot of additional effort and a big opportunity for Mr StuffUp to enter the picture. Maybe at a later date! Thanks for the DS1666 solution - looks like the sort of thing I was after. Cheers all.
Old 9th December 2008, 01:57 AM   #6
gingertube is offline gingertube  Australia
I get the Dallas / Maxim Engineering Journal and Design Guides sent to me in my day job.
3 more to look at (their descriptive prose, my comments):
#1
"Simplest Pushbutton Interface Controls Audio Volume and Balance" - MAX5457
My notes:
2 independent 10K Ohm potentiometers, will need buffer to drive that impedance
32 tap audio taper, steps of 2dB
UP, DOWN, MODE, MUTE(-90dB) Push Buttons
MODE toggles between Balance and Volume, there is a LED driver to indicate the mode.
Shutdown pin (active low) - stores last wiper position.
Same thing with separate Volume and Balance Up Down switches is MAX5456
#2
"Push Button Audio-Control IC Mixes Two Independent Stereo Sources" - MAX5406
My notes:
VOL UP/Down Switches
BALANCE L/R Switches
BASS UP/DOWN Switches (external Cap to set operating freq)
TREBLE UP/DOWN Switches (external Cap to set as above)
"AMBIENCE" Switch (artificially "enhances" stereo separation)
MUTE Switch
50K Input Impedance
32 step audio taper, 2dB per step
Pseudo Stero for Mono Sources
Sub Woofer Output
Shutdown store last Wiper Settings.
#3
"Rotary Encoder IC Controls Volume and Balance without uC" - MAX5440
My notes:
Integrated low power <0.003% THD Buffers
5 segment LED Setting Indicator shows Volume or Balance
-12dB Power on Reset
32 Tap Audio Taper
-90dB Mute.
Ian
Old 9th December 2008, 05:56 AM   #7
analog_sa's Avatar
Surprising suggestions Gingertube: all seriously lo fi.
Old 9th December 2008, 01:41 PM   #8
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
A lot of people use the one i link below, myself included.
http://www.diyaudio.com/forums/showt...2&pagenumber=1
Old 9th December 2008, 02:59 PM   #9
Boris_The_Blade is offline Boris_The_Blade  United States
Boris_The_Blade's Avatar
http://www.profusionplc.com/pro/gex/...rtno=MAS6116AA
A copy of the (discontinued) Wolfson WM8816.
Old 10th December 2008, 10:05 AM   #10
peterr is offline peterr  Netherlands
peterr's Avatar
Guido Tent sells THIS
Keep an open mind. It helps.
Peter
digital volume controlHide this!Advertise here!
Digital Volume Control soundNERD Chip Amps 17 3rd June 2011 08:00 PM
Digital volume control day1118 Digital Line Level 8 21st November 2008 08:11 PM
Digital volume control maharadza Digital Source 9 8th April 2006 04:59 PM
Which VCA for Digital volume control gmphadte Analogue Source 8 30th September 2004 11:21 AM
Digital Volume control for in Car use dunderchief Digital Source 7 28th March 2004 12:08 AM
