| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi!
I made a board for linear regulators, a bit on the "universal" side (should serve me in many projects). It's designed to use the LT1963 or LT1763 chips that are pin compatible. However, I would avoid making another board to do a neg version of it, using the LT1964, as this chip is NOT pin compatible with the LT1763 - quite sad. These chips are SMD devices. I thought I could make a small board to be a pin adapter. So this board would receive a SOT5 device on top of it (no problem here) and be soldered on the SO8 footprint on my regulator board. This board would be soldered like a smd chip - more like a BGA chip. Do you think it is possible? Using solder paste / reflow oven. I think it should work, I'm not absolutely sure about it but... Thanks! Nicolas |
| Sure Electronics New Tripath Board 4*100W class-D Amplifier Board | 7788q | Class D | 305 | 8th February 2012 04:24 PM |
| PCB to PCB board style connectors | rtarbell | Parts | 8 | 8th October 2008 11:55 PM |
| My Cambridge 500SE, needs an output board (to replace internal DAC Board) | slbender | Digital Source | 0 | 15th May 2008 02:36 AM |
| Soldering TP2350B chip to the board on AMP2 | luka | Class D | 1 | 7th December 2007 02:22 PM |
| Soldering and overheating of circuit board | KT | Parts | 2 | 3rd June 2005 04:43 AM |
| Page generated in 0.07246 seconds (67.27% PHP - 32.73% MySQL) with 10 queries |
