| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm making a preamp for my bass guitar . The circuit design is almost complete apart from a problem i have run into with the volume pot. the volume pot needs to recieve the input signal from the passive circuit and the active circuit. The active would need a volume pot of around 25K ohms and the passive would need a pot of 250K ohms.
Is it possible to get double ganged rotary pots like this, that have 2 resistor tracks, 2 inputs and a single or double output? (basically 2 pots built into one, with only control shaft)
#2 |
you can find dual element dual concentric pots. that would be one shaft that is split in two so that there are two separate control knobs stacked. 25k and 250k might be a special order but you can find it.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#3 |
Magneto the Gravity Man
Special order ? What's that?
Buy 2 dual pots, identical except one at 25k and one at 250k Dismantle by carefully unbending the tabs and reassemble with one 25k and one 250k. Simple, eh? Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#4 | |
| C and L of potentiometers? | Christer | Parts | 2 | 26th June 2007 12:26 PM |
| potentiometers | zahlm | Parts | 1 | 15th April 2004 06:43 AM |
| Page generated in 0.73499 seconds (8.78% PHP - 91.22% MySQL) with 10 queries |
