Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th December 2008, 04:01 AM   #11
Send a message via MSN to jomatecc Send a message via Yahoo to jomatecc
Originally posted by umut1001
and also another question.there was 47uf elna tonerex cap for feedback.when i short circuit amp starts to give large dc to the output.can i use mks4 wima 68uf capacitor as a feedback capacitor instead of bipolar nichicon muse es?thanks
The Wima MKS4 68u will work just fine I use a pair in my gainclone amp --- sounds clear as a bell, size may be a problem though measure 41.5mm long with over 35mm pitch but worth the effort fitting it.
regards
Music: Please audition with your ears not your eyes.
Old 8th December 2008, 01:05 PM   #12
impsick is offline impsick  United States
impsick's Avatar
the ERO KC1853 are good. Or the EROMAK FKE. Film/Foil types over metalized types are my preference. ERO KP1832, Wima MKP10.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 8th December 2008, 01:28 PM   #13
umut1001's Avatar
i tried ero and mundorf..i liked mundorf rxp very much..is there any web site that i can buy online mundorf caps with cheap price?thx
Old 8th December 2008, 02:37 PM   #14
impsick's Avatar
cheap? lol
Old 8th December 2008, 03:00 PM   #15
umut1001's Avatar
i mean mcap series of mundorf..they are not expensive and good enough..well sound..i need 4 more..
Old 12th December 2008, 08:45 PM   #16
Default Ampohms
FYI, Ampohm manufacture the following values in metallized polyprops at 630VDC in standard housing:
1.0uF
1.5uF
1.8uF
2.2uF
3.3uF
3.9uF
4.7uF
6.8uF
8.2uF
10.0uF
12.0uF
16.0uF
20.0uF
24.0uF
30.0uF
40.0uF (only in aluminium housing at present).
Hope this is useful - let me know if you need sizing or other data....
Old 12th December 2008, 08:50 PM   #17
umut1001's Avatar
hi..i bought 0,5uf kp1832 capacitors today..price is cheap..its 0,5 dollars each..someone says they are better than mkp..what is the max capacitance of these caps? thanks
Old 12th December 2008, 09:06 PM   #18
umut1001's Avatar
ampohm caps are expensive and the dissipation factor of ampohm(0,001) is not better than ero and mundorf...and i will use caps for feedback path of the amp..i dont need 630 volts of capacitors.they are so big and expensive.63volts 60uf or 100uf enough for me..
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Oil capacitors Praudio Swap Meet 3 7th October 2003 03:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.09582 seconds (74.80% PHP - 25.20% MySQL) with 10 queries
