Takman: a new audio resistor - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th November 2009, 03:08 PM   #31
tubesteve's Avatar
Location: since 1998 in China as an electronic consulting design and testing engineer
Send a message via Skype™ to tubesteve
are there new materials from outside the world coming to make resistors?
Old 8th November 2009, 03:10 PM   #32
Banned
Not that I am aware of. Do you have alien source that you are not telling the rest of us about?
Old 8th November 2009, 03:36 PM   #33
SY's Avatar
How about resistors made from quasi-1-dimensional molecular chains using polaron charge transport?
File Type: pdf Electronic_device_fabrication_on_non_con.pdf (182.9 KB, 297 views)
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th November 2009, 10:15 AM   #34
cjcc67 is offline cjcc67  Australia
Do i get carbon credits if i use metal films?
Old 10th November 2009, 04:23 PM   #35
Banned
If so please let me know
Old 11th November 2009, 04:02 AM   #36
Default What does the black resistor color mean?
Originally Posted by Geek View Post
Too much current through the pink resistor
Holy cow - I blew snot out my nose from laughing at this one.....
Old 11th November 2009, 04:26 AM   #37
Geek's Avatar
Your response is as good!
Cheers!
Old 12th November 2009, 06:41 AM   #38
nanchangbob's Avatar
Default nice fairly inexpensive resistors
I used the Takman REY metal film resistors in various positions throughout my Jolida JD-502 amp with good results. The sound is fairly extended with good information retrieval. I did however change the grid stop resistors to Riken RMG's and found them to be more organic and for some reason the sound stage is also deeper. Also the instruments are better defined. But from what I have read you can't use too many of them. Overall the Takman's are a good value and would like to try the REX version.
Old 13th November 2009, 03:00 PM   #39
rok-n-rol's Avatar
Default looking outside
Sy- One drawing in the acid doping decript looks like a Buckyball space rope resistor I hear NASA is holding in their Alien Tech files. Sounds bad I know.
Old 13th November 2009, 04:44 PM   #40
tubesteve's Avatar
Default resistors
organic resistors: can i cook and eat them? or is ET already here? how about organic transformers etc.?
Audio Note Tantalum Resistor (1%) US$3 each. Worth using it loong Chip Amps 10 17th August 2016 07:48 AM
Takman Designed-for-Audio Resistors bcherry DIY HiFi Supply 2 4th October 2012 03:30 AM
Audio note M2 power supply resistor value drobert Tubes / Valves 0 20th November 2007 11:01 AM
Audio Research Resistor Type Algar_emi Tubes / Valves 10 25th May 2006 10:04 PM
How do you make an audio potentiometer into a variable resistor? Darren Nemeth Parts 1 10th February 2005 08:15 AM
Copyright 1999-2017 diyAudio
