Making and onboard bass guitar preamp
I have a passive set up on my bass. 2 soapbar pickups, 2 vol pots and a tone pot. I'd like to add an active preamp with a 3 band EQ with a mid sweep/freq select control. and also with a passive/active switch, so i can switch between the passive ciruit and the active preamp.
So in total there would be 6 knobs and a switch. Bridge p-up vol (pass) Neck p-up vol (pass) Tone (pass) Pup vol (activ) (push pull p-up select pot) Treble (active) Bass (active) Mid/Mid Sweep (active) (stacked pot) Active/Passive switch Does anyone have a schematic for such a set up? |
Actually a slight change to the lay out...
Tone - for both Passive and Active Treble - Active Mid/Mid Sweep - Stacked pot- Active Bass - Active Pickup Blend - Passive and Active Volume - Passive and Active Passive/Active Switch There's a preamp made by John East which is almost exactly like what i want , but i reckon if i can figure out how to make it (with my modifications) it would be alot cheaper. My design is a hybrid of the John East U-Retro 01 Deluxe and the U-Retro 5 Knob deluxe. John East Preamps |
http://www.sputnikmusic.com/lesson.php?lessonid=195
go there and check out their build. Im not 100% if it will do the same thing for a bass. Some of the values may need to be changed to accommodate a Bass I believe a bass pick-up puts out a little more juice than a guitar. I am A very new noob DIYer, but this is a build I plan on doing for my Ibanez SZ |
Actually, all you really need to do is add is the 3 band preamp.
Have a squizz at the Aguilar wiring diagrams: http://www.aguilaramp.com/pdf/support_wiring_obp3.pdf Look at the diagram with the bypass switch, all you're doing is adding a tone knob before the switch. Its been a while since I looked but you might have some drama finding the right pot to do the mid+mid sweep function, I had looked for one but gave up for an unknown reason. In fact, using an OBP-3 (or similar 3-band) will save you the drama of tuning your DIY design for the right frequency responses and is a reasonable price (IMO). Have you looked at the Audere? The z-mode is rather tremendous (again, IMO). |
in my search for some circuits for help with my preamp design i came across the circuit shown below.
My preamp is going to have Passive/Active DPDT switch Tone (pasive and active) Bass and treble stacked pot (Active) Mid with mid sweep stacked pot (Active) Volume Blend I plan on taking the pickups into the blend pot then to the input (im going to change out the boost switch in the circuit for a trim pot that will go on the board) then throught to the preamp and EQ. Where would i add the tone pot and the passive/active switch in this circuit? How would i alter the "Mid" section to include a mid sweep? |
O.K. well I went to radio shack (doh!!) and bought the parts I need to build this. However the T1 calls for a BC548. the closest thing I could find was a PN2907. Do I have anything to consider before wiring this up ?[IMG]<a href="http://s107.photobucket.com/albums/m318/unohu69/?action=view¤t=preampsch-1.gif" target="_blank"><img src="http://i107.photobucket.com/albums/m318/unohu69/preampsch-1.gif" border="0" alt="preamp ?"></a>[/IMG]
I didn't mean to commandeer this post, just figured since we were on the subject. |
2 Attachment(s)
Darn wasn't sure if that image was gonna work... so here goes this .....
i was really disappointed in RS quality. +/- 20% WTF is that. how do I get better quality parts ? +/- 10 or even 1 % ? |
4 band all sweepable preamp
Suppose I want to make a preamp that all four frequencies act as bells (no shelfs) and have sweepable frequencies, something like:
Bass +-12db 60-600hz Low mid +-12db 100-1khz Hi mid +-12db 600-6khz Hi +-12db 1kz-10khz Volume Passive balance (between passive mag pups before pre) Active Balance (between piezo pups and mag) Does anyone know a module or can come up with a schematic? |
| All times are GMT. The time now is 11:03 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
