| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I would like to build an active filter for my vented subwoofer. Would Rod Elliot project 71 be suitable for this purpose ? http://sound.westhost.com/project71.htm
There are many circuits shown on the page. Is figure 4 the circuit i should be building ? I dunno if it is complete or if some stuff is missing. |
#2 |
What do you want the filter to do? The circuit you linked to is typically used to extend bass response below resonance in a sealed box - it would be useful, for example, if you chose to seal the port on your current sub and then wanted to reclaim bass extension.
I don't think that's what you're trying to do. Perhaps you were looking for a rumble filter? http://sound.westhost.com/project99.htm Or maybe you're after an active crossover? http://sound.westhost.com/project09.htm Or perhaps you were after a graphic subwoofer equaliser? http://sound.westhost.com/project84.htm Please elaborate on what you're trying to achieve. |
#3 |
oops sry. What i want is to cutoff the low frequencies to save my sub from over-excursion.
Btw is it ok to supply opamp with just +12 and -12V dc instead of the +15 -15V ? |
#4 |
look up sixth order alignment.
It adds a little bit of equalisation and a 12dB/octave high pass filter to a vented enclosure. However the enclosure/driver needs to be designed in conjunction with the filter.
regards Andrew T. |
#5 | |
diyAudio Moderator Emeritus
Brian |
#6 | |
#7 |
The one you want is Project99 - the rumble filter.
Brian |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 02:12 PM |
| Active Filter | ChevS-10 | Solid State | 4 | 24th June 2005 06:35 PM |
| my active filter | merlinx76 | Chip Amps | 34 | 23rd February 2005 06:12 PM |
| subwoofer bass extension active filter? | capslock | Subwoofers | 8 | 12th September 2002 06:05 PM |
| active filter | janey | Solid State | 2 | 7th September 2001 10:30 PM |
| Page generated in 0.09873 seconds (81.66% PHP - 18.34% MySQL) with 10 queries |
