Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th November 2008, 06:38 PM   #1
luvdunhill's Avatar
Default Spongy SMD regulator heat sink?
Hey guys!
I have a small SMD regulator that needs a bit of heat sinking. It is about 1/8" away from the plastic housing, but at this point it is slightly curved. Is there some sort of spongy heat transfer material out there that might be appropriate in this situation?
Old 24th November 2008, 07:15 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Can you fashion a small piece of metal (preferably aluminum or copper) to the package with double sided tape or super glue? That would be better than any kind of spongy, non-metal material.
Brian
Old 24th November 2008, 08:11 PM   #3
luvdunhill's Avatar
I guess I was wanting to couple it to the case, but it's plastic so maybe that won't do all that good, but in my head I was thinking it would work better than just a piece of metal... it's worth a try though.
Old 29th November 2008, 12:42 AM   #4
Fujipoly has gap filler pads to transfer heat.
http://www.fujipoly.com/products/gen...face_Materials
Old 29th November 2008, 09:08 PM   #5
nonoise is offline nonoise  South Africa
You could also try
http://www.lairdtech.com/pages/produ...oduct-Line.asp
and
http://www.bergquistcompany.com/tm_gap_pad_list.cfm
look for a low pressure material with a high W/mK rating and were possible try to use the thinnest material that will still conform to your component.
The plastic box however is you enemy, you could use the material only as a medium for coupling the heat to another more suitable heat spreader or heat sink.
Aleph P1.7 heat sink? sugano Pass Labs 1 11th July 2006 02:56 PM
DH-500 heat sink assembly Dick West Swap Meet 2 13th April 2005 03:51 AM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
Page generated in 0.07610 seconds (71.05% PHP - 28.95% MySQL) with 10 queries
