Inundated Electrolytics - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th November 2008, 04:17 AM   #1
mach1 is offline mach1  Australia
mach1's Avatar
Default Inundated Electrolytics
My workshop got flooded recently, wetting lots of electrolytic caps which are now in the process of air drying.
Does anyone know whether they are likely to have suffered any permanent damage from this treatment ?
'Symmetrical equations are good in their place, but 'vector' is a useless survival, or offshoot from quaternions, and has never been of the slightest use to any creature.' Lord Kelvin
Old 24th November 2008, 04:39 AM   #2
HollowState's Avatar
I'm sorry to read about this but I suspect that they will be OK. They should be pretty much water tight. I might heat them up a little with a hair blow drier to help drive out any remaining moisture that might have gotten between the jacket and the can itself.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2016: 18 year olds need a safe place because words hurt their feelings.
Old 24th November 2008, 05:19 AM   #3
I doubt it as long as they weren't charged / short circuited, most of them should be fine.
Old 24th November 2008, 05:50 AM   #4
mach1's Avatar
Thanks guys - I might try the hairdryer trick. There were a few black gates and cerafines in there which I would hate to lose.
Old 24th November 2008, 12:16 PM   #5
jackinnj's Avatar
You will find to your surprise that most electrolytics carry a charge all the time. Bob Pease discussed this in one of his National Semi discussions calling it capacitor "soakage".
I purchased a pair of Fairchild tube amplifiers about 15 years ago -- they had been in a flood. As they were early 60's vintage the caps were destined for the ash-heap of audiocrapola. With one of the amps I emptied out the aluminum shell and put a new electrolytic inside the hollowed out tin.
Our house floods about once every couple of years. The most irritating was the rupture of a hot water heater, but there have been occasions where we get a torrential rain which overcomes the drains in the window wells. As a result I keep everything a few inches off the floor.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 24th November 2008, 01:22 PM   #6
I agree with what hollowstate said... hopefully those things will still be ok after drying out. Good Luck
Old 24th November 2008, 02:15 PM   #7
Electrolytics would soon die if they weren't water tight. I'd rinse with clean water, and maybe scrub the ends with a tooth brush if necessary, then bake dry at a low temperature. You might even consider putting them through the dishwasher in a mesh bag with two caveats- no dishwasher detergent, as this damages aluminum, and don't use the heated dry setting- probably too hot.
I may be barking up the wrong tree, but at least I'm barking!
PSU capacitors/electrolytics knubie Tubes / Valves 27 14th April 2012 12:34 AM
Old electrolytics never die, they only.... Pbassred Solid State 13 9th October 2010 01:55 PM
ARC D90 needs new electrolytics Pete22 Tubes / Valves 9 4th August 2006 12:31 AM
Affordable electrolytics bremen nacht Parts 8 2nd July 2004 12:12 PM
Electrolytics 101 Frazzled Parts 3 21st May 2004 02:49 AM
Copyright 1999-2017 diyAudio
