Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd November 2008, 10:35 AM   #1
405man is offline 405man  Scotland
Default CD4066 Switch replacement
Can anyone recommend a modern low distortion pin compatible replacement for the CD4066 or failing that something that is not pin compatible
Stuart
Old 23rd November 2008, 12:21 PM   #2
I've found for some older equipment, only a 4066 will do. The CD4066B and many others are an active component with TI, and you can order right from their web site. There are many "DG" prefix parts like DG419 that are good for new designs, depending on voltage, number of switches, etc, but I don't think a drop in for the 4066 exists. Look at 4016 too.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 23rd November 2008, 04:08 PM   #3
jcx is offline jcx  United States
"updated" 4066:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1262
need to compare specs and application
sometimes "improvements" in specs for one app are wrong for another
Old 24th November 2008, 01:04 PM   #4
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
The 4066 is basically a better spec 4016. Lower on resistance. As always, it depends on the application as to how well they perform.
What are they in. Not a Quad is it ?
Old 24th November 2008, 02:27 PM   #5
Yes they are in a Quad 66 preamp and I was wondering if there was something better
Stuart
Old 25th November 2008, 06:53 AM   #6
Mooly's Avatar
Never seen the 66 ( Only the 44 etc ) circuit so can't really comment. Used correctly though the CMOS switches are pretty transparent to audio. The secret is configuring them so that no audio voltage is ever developed across the switch, which usually means using them in as part of a "virtual earth" opamp arrangement.
Old 21st November 2009, 02:49 PM   #7
I am thinking of subtitute the 4066 with TS3A44159 from analog Device etc. so that a better signal transfer is acheived across the switches as compared to 4066.Anyway I am totally new in this area so practical advise is needed.
Old 21st November 2009, 04:28 PM   #8
Mooly's Avatar
You might be better starting a new thread for this question.
Never heard of the IC you mention but as a general rule a lot depends on the exact application. If the switch can be arranged so that for example it works into a virtual earth amp then the effects of it are negligable as there is never any voltage developed across it.
I used discrete FET's to achieve the same result,
replacement for Bidirectional Switch MBS4991 and Triac 2N6346A qsa Solid State 3 7th May 2009 03:10 AM
b&k st-140 toggle switch replacement thezaman Solid State 0 29th May 2008 01:57 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Main on/off switch for amp using a piezo switch using_e Solid State 13 20th June 2006 05:55 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Page generated in 0.08800 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
