Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd November 2008, 03:50 AM   #1
Default Voltage in and out of an isolation transformer?
Why am I not measuring the same voltage on the primary and secondary of an isolation transformer? I'm using a triad n68x isolation transformer for a power transformer for the analog stage of my dac. It measures 120V on the primaries and 139 VAC on the secondaries and 178 VDC on the output of the Schottky bridge and 1uF film cap.
I thought an isolation transformer is supposed to generate the same output voltage as the input voltage? What would be the reason I am measuring 138 VAC on the output?
Cheers ~ Mike
Old 23rd November 2008, 12:34 PM   #2
dmills is offline dmills  United Kingdom
I am guessing you are very lightly loading the transformer?
All transformers have losses, so to make up for this the windings will not be quite 1:1 so that when under full load the extra voltage cancels the winding losses to provide the correct voltage output.
Small transformers have worse regulation then large ones, so a small transformer lightly loaded will have a higher secondary voltage then a large one lightly loaded.
16 percent is poor however, and I am wondering if the waveform is a bit off and your meter is assuming a sine or something.
Regards,Dan.
Old 24th November 2008, 07:11 PM   #3
Thanks Dan! That explains it.
Cheers ~ Mike
Old 30th November 2008, 11:24 AM   #4
I recently purchased a 1KVA isolation transformer and couldn't understand why all of the transformers in attached components buzzed when connected to it.
I measured Vin and Vout and found that the isolation transformer was raising the supply from 240V to >250V (hence the buzzing).
I reversed primary and secondary to give me Vin = 240V and Vout = 230V. This brought about a correspondingly significant drop in component transformer buzz compared to direct connection to the mains - bonus!
isolation transformer - high voltage. atmars Tubes / Valves 7 16th July 2008 04:34 AM
transformer isolation? zlast Everything Else 1 19th June 2006 10:33 AM
High voltage isolation from set-top-box ? bordins Solid State 3 11th December 2005 08:00 AM
transformer isolation dmitriy167 Solid State 24 2nd March 2005 03:01 AM
Isolation Transformer HarryHaller Solid State 9 5th August 2002 12:30 PM
Page generated in 0.07312 seconds (70.43% PHP - 29.57% MySQL) with 10 queries
