Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th November 2008, 10:30 PM   #1
Bassivus's Avatar
Default Inductor trouble
today I got the package with OFC foil inductors I ordered online.
Unfortunately one got broken lexan ring in the middle.
I was planning using them in PSU of amp.
Should I try to repair it or should I ask for replacement. It took 3 weeks to arrive so you understand why I'm considering reparation...
...is I disappear. There is ONLY the music.
Old 24th November 2008, 11:57 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
A piece fo wood would do just fine.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 25th November 2008, 07:18 AM   #3
Bassivus's Avatar
Thanks for the reply!
Not very visited part of the forum.
I was thinking similar, or just strap it with the 3 or 4 those nylon straps... you know the type that make trrrrrrt when you fasten them
Old 25th November 2008, 05:08 PM   #4
Magura's Avatar
I would be careful with trrrrrrt (zip ties) and the soft polypropylene isolation.
Go hack a log off your favorite tree, and paint it in a fancy color
Or as I see you have access to the "red" inventory, I bet you can find yourself a nice piece of either polyamide (nylon) or perhaps even easier for you to find, PTFE (teflon).
If you end up in a real tight spot, drop me a mail, and I'll sort you out. I have done a bit of machining of plastics from time to time, and I sure have two small pieces of something nice somewhere.
Magura :-)
Old 25th November 2008, 05:10 PM   #5
Magura's Avatar
BTW have you checked the inductor isn't damaged electrically ?
Magura
Old 25th November 2008, 09:11 PM   #6
scottw is offline scottw  United States
I'm not sure what the insulation rating is on these inductors is but these are usually used for speaker cross overs- i.e., low voltage and high current. If you are making a psu filter there may be a cheaper, more appropriate "iron rich" alternative.
Also, I wonder what must have happened to these to break the middle piece? The inner windings may have loosened which may be less than ideal, as these are wound to be tight and solid.
Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?"
-Adobe Updater
Old 25th November 2008, 10:01 PM   #7
Bassivus's Avatar
Hi, I have checked them for conductivity and its fine. Good thing is that they did not get loosened except the first inner row.
They were packed one buy another and my guess is the got crashed inside the package by their own mass inertia when package was mishandled-thrown by post office . They together weight about 1,6 Kg!
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Air Inductor shugg Multi-Way 3 10th July 2009 08:42 AM
WTB: Inductor budwiser Swap Meet 1 10th April 2009 06:55 PM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
SOZ inductor Mad_K Pass Labs 1 23rd January 2003 08:11 PM
Page generated in 0.09460 seconds (79.20% PHP - 20.80% MySQL) with 11 queries
